[MPICH] test/mpi/comm/cmfree.c
Rajeev Thakur thakur at mcs.anl.gov
Fri Jul 13 10:37:21 CDT 2007
The current version of the test is attached.
Rajeev
> -----Original Message-----
> From: Toon Knapen [mailto:toon.knapen at fft.be]
> Sent: Friday, July 13, 2007 3:02 AM
> To: Rajeev Thakur
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] test/mpi/comm/cmfree.c
> Rajeev Thakur wrote:
> > Correction!  The test is ok as it is. The comm_split is on
> a different
> > communicator.
> The communicator I am talking about is a communicator that is created
> directly after the MTest_Init as follows:
> MPI_Comm_dup(MPI_COMM_WORLD,&comm);
> > And a comm_free is called at the very end of the program if
> > comm != null.
> I do not see this (at least not in mpich2-1.0.5p4).
> Additionally IMHO it
> would not make since to test it to be different from comm_null before
> comm_free'ing it because if this comm would be comm_null, the
> test would
> completely fail because this comm is used to determine the
> rank of every
> process etc which is used further down in the algorithm.
> Actually, its a library of mine (that I link with the test) that
> detected the communicator-leak. I first thought it was an error of my
> library but finally I think that indeed there is a communicator-leak.
> But of course, I might be overseeing something.
> Thanks again in advance,
> toon
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070713/6b452966/attachment.obj>
