[MPICH] communication between linux and windows
Jayesh Krishna
jayesh at mcs.anl.gov
Wed Jan 24 09:56:12 CST 2007
The error message says that host name resolution failed for one of the hostnames specified. Try specifying ip addresses of the machines on which you want to run your program. Please try running the mpiexec command on both the machines and let us know the results (Provide us with the command and the complete output).
If the error persists please provide us a detailed information on the systems (which node is linux and which is windows, where are you running the mpiexec command ? etc) you are running your program. Also please try running the sample program (cpi.exe) that is provided with the MPICH2 installation (Windows).
Jayesh
Jayesh Krishna
Argonne National Laboratory
Mathematics and Computer Science
Email: jayesh at mcs.anl.gov
_____
From: owner-mpich-discuss at mcs.anl.gov [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of wangtianyou at tech.ist-jp.com
Sent: Tuesday, January 23, 2007 7:44 PM
Subject: [MPICH] communication between linux and windows
Hello,everyone .
Now I puzzled about the processes running on both linux and windows(mpich2).
Firstly ,I used two machines for the test (one windowsXP,one fedora3 ).The windows saves as root.
And then ,and running the smpd on both two machines.
When I input the command as follow for test
mpiexec -host ***.***.**.1 -n 6 hostname : -host ***.***.**. 2 -n 6 “/bin/hostname”
the command was executed;
but when I was running a small programme like “hello world”
there were errors below:(launch 4 processes totally)
Hello world from process 0 of 4
Hello world from process 1 of 4
job aborted
error message:fatal error in MPI_Finalize: other MPI error,error stack:
MPI_Finalize(234)............:MPI_Finalize failed
MPI_Finalize(154)............:
MPI_Finalize(83).............:
MPI_Barrier(406).............:MPI_Barrier(MPI_COMM_WORLD)failed
MPI_Barrier(77)..............:
MPI_Sendrecv(119)............:
MPID_Isend(102)..............:failure occurred while attempting to send an eager maessage
MPIDI_CH3_iSend(164).........:
MPIDI_CH3I_VC_post_sockconnect(1059):[ch3:sock]rank 2 unable to connect to rank 3 using bussiness card
MPIDU_Sock_post_connect(1228).......:unable to connect to amon on port 3284
MPIDU_Sock_post_connect(1244).......:gethostbyname faild
I have turned off the firewall completely,and the programme uses the code which is the example in the package of mpich2.
Any help ??
Thanks and Regards
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070124/01370eae/attachment.htm>
