[MPICH] communication between linux and windows
wangtianyou at tech.ist-jp.com
Tue Jan 23 19:43:41 CST 2007
Hello,everyone .
Now I puzzled about the processes running on both linux and
windows(mpich2).
Firstly ,I used two machines for the test (one windowsXP,one fedora3
).The windows saves as root.
And then ,and running the smpd on both two machines.
When I input the command as follow for test
mpiexec -host ***.***.**.1 -n 6 hostname : -host ***.***.**. 2 -n 6
“/bin/hostname”
the command was executed;
but when I was running a small programme like “hello world”
there were errors below:(launch 4 processes totally)
Hello world from process 0 of 4
Hello world from process 1 of 4
job aborted
error message:fatal error in MPI_Finalize: other MPI error,error stack:
MPI_Finalize(234)............:MPI_Finalize failed
MPI_Finalize(154)............:
MPI_Finalize(83).............:
MPI_Barrier(406).............:MPI_Barrier(MPI_COMM_WORLD)failed
MPI_Barrier(77)..............:
MPI_Sendrecv(119)............:
MPID_Isend(102)..............:failure occurred while attempting to send
an eager maessage
MPIDI_CH3_iSend(164).........:
MPIDI_CH3I_VC_post_sockconnect(1059):[ch3:sock]rank 2 unable to connect
to rank 3 using bussiness card
MPIDU_Sock_post_connect(1228).......:unable to connect to amon on port
3284
MPIDU_Sock_post_connect(1244).......:gethostbyname faild
I have turned off the firewall completely,and the programme uses the
code which is the example in the package of mpich2.
Any help ??
Thanks and Regards
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070124/f51564f4/attachment.htm>
