[MPICH] MPICH2 1.05 MPI_Send & MPI_Recv dropping packages randomly
Rajeev Thakur
thakur at mcs.anl.gov
Thu Jan 18 11:43:37 CST 2007
Can you try using the Nemesis channel? Configure with
--with-device=ch3:nemesis. That will use shared memory within a node and TCP
across nodes and should actually perform better than ssm.
Rajeev
_____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of chong tan
Sent: Thursday, January 18, 2007 11:11 AM
To: William Gropp
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [MPICH] MPICH2 1.05 MPI_Send & MPI_Recv dropping packages
randomly
all the messages are short messages, the shortest being 3 integer (32 bits),
the longest 9 integers.
I can't send you the code per company policy. There are about 3 million
lines of C, C++ and Tcl. MPI is used in an isolated part of the code.
I will try sock, sock runs almost 11X slower on this prtiticular machine.
On 2.1.04p1, overhead by ssm was 50 sec, and sock's overhead was 520 sec on
the failed test.
tan
----- Original Message ----
To: chong tan <chong_guan_tan at yahoo.com>
Sent: Wednesday, January 17, 2007 6:37:19 PM
randomly
Can you send us the test case? Does it fail with the ch3:sock device? Are
the messages short or long?
Bill
On Jan 17, 2007, at 7:06 PM, chong tan wrote:
OS : RedHat Enterprise 4, 2.6.9-42.ELsmp
CPU 4 dual core Intel
the package was built with :
setenv CFLAGS "-m32 -O2"
setenv CC gcc
./configure -prefix=/u/cgtan/my_release_dir --with-device=ch3:ssm
--enable-fast |& tee configure.log
the test programs run 5 processes, one master and 4 slaves. Master always
recv from slaves and them send to all of them. Randomly, an MPI_Send
performed in the master will complete, but the corresponidng MPI_Recv in the
targeted slave would not complete, and the who thing hangs.
I have a debugging mechanism that attachs a sequence id to all packages
sent. The packages are dumped before and after sent, and recv. a message
is also dumped on the the pending recv. The sequence id traced OK all the
way to the lost package.
The same code work fine with 2.1.04p1. it has been tested on test cases
longer than 100 million send/recv sequences. any suggestions ?
tan
_____
<http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com> Bored stiff?
Loosen up...
<http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com> Download and
play hundreds of games for free on Yahoo! Games.
_____
Now that's room service! Choose
<http://travel.yahoo.com/hotelsearchpage;_ylc=X3oDMTFtaTIzNXVjBF9TAzk3NDA3NT
g5BF9zAzI3MTk0ODEEcG9zAzIEc2VjA21haWx0YWdsaW5lBHNsawNxMS0wNw--> from over
150,000 hotels
in 45,000 destinations on Yahoo! Travel to find your fit.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070118/eb3ab58d/attachment.htm>
