[MPICH] clog2TOslog2 conversion failure
Anthony Chan chan at mcs.anl.gov
Wed Jan 17 19:04:15 CST 2007
Is your program running normally without MPE logging ?
Or is the problem Windows specific, did you try it on
other OSes ?
If your program is small, send me your program so
I can try to reproduce the problem here ?
A.Chan
On Wed, 17 Jan 2007, Glaser, Amnon wrote:
> Hello All
> I am using MPICH ver mpich2-1.0.2-1-win32-ia32
> with mpe for logging events.
> My application used to work very well with mpe and the clog2 files
> translated
> smoothly to slog2 files I could use in jumpshot-4.
> I added to my application non-blocking receive using the following MPI
> commands:
> * MPI_Recv_init
> * MPI_Start
> * MPI_Test
> * MPI_Request_free
> Now the application works well and clog2 file is created but the
> conversion to slog2
> always FAILS with the error message I attached below.
> I would appreciate any advice on how to solve that problem
> and be able to use jumpshot-4 again.
> Thanks allot
> Amnon
> -----------{ clog2TOslog2 error report }-----------------
> Executing C:\Program Files\Java\jre1.5.0_05\bin\java.exe -Xms32m -Xmx64m
> -jar C:\Program Files\MPICH2\bin\clog2TOslog2.jar -o
> c:\bin\AppDbg.exe.slog2 c:\bin\AppDbg.exe.clog2 ....
> Error > java.lang.NullPointerException
> Error > 	at
> logformat.clog2TOdrawable.InputLog.peekNextKind(InputLog.java:226)
> Error > 	at
> logformat.slog2.output.Clog2ToSlog2.main(Clog2ToSlog2.java:73)
> Error > Offending RecHeader = RecHeader[ timestamp=0.010229941457509995,
> rectype=5, taskID=0 ]
> Error > Offending RecBare = RecBare[ etype=-858993460 ]
> > Ending with exit status 1
> Amnon Glaser
> Algorithms Architect
> EFW Inc. (San Diego)
> Phone: (858) 623-3671
> Fax: (858) 642-6958
> http://www.efw.com
> _______________________________________________________________________
> This e-mail message has been sent by EFW Inc. and is for the use
> of the intended recipients only. The message may contain privileged
> or confidential information. If you are not the intended recipient
> you are hereby notified that any use, distribution or copying of
> this communication is strictly prohibited, and you are requested to
> delete the e-mail and any attachments and notify the sender immediately.
