[MPICH] Error using MPI_WAITALL
Vadivelan Ranjith achillesvelan at yahoo.co.in
Mon Feb 12 22:14:51 CST 2007
If there is a bug in the code, it won't run on any machine. All machine should give some error. But our code is running on some machines(Dual-Core),  but not on othermachines(quad-core). I installed the same mpich2-1.0.3 in both machines and configured simillarly.
Velan
Rajeev Thakur <thakur at mcs.anl.gov> wrote:     It's likely a bug in the code, as it says invalid request.  Just removing MPI_Waitall is not a good solution as it is needed for a  correct program.
 Rajeev
   From: owner-mpich-discuss at mcs.anl.gov    [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Vadivelan    Ranjith
Sent: Sunday, February 11, 2007 10:55 AM
To:    mpich-discuss at mcs.anl.gov
Subject: [MPICH] Error using MPI_WAITALL
 Hi
  I am using mpich2-1.0.3 to compiling our code. Our code is    calling
  MPI_WAITALL. We ran the case    in intel-Dual core without any problem
  and solution was fine. I tried to ran the code in intel    quad-core.
  Compilation using mpif90 is    fine. I started running the executable
  file, i got the following error.
  Fatal error in MPI_Waitall: Invalid MPI_Request, error stack:
  MPI_Waitall(241):    MPI_Waitall(count=250, req_array=0x23e52e0,
  status_array=0x7fbfffe3a0) failed
  MPI_Waitall(109): Invalid MPI_Request
  So i removed all the lines where MPI-WAITALL is using. Again i
  compiled to code using mpif90(mpich)    and ran it. Now its running
  without    any problem. Can you please explain me what is happen here.
  Thanks
  Velan
   Here’s a new way to find what you're looking for - Yahoo!    Answers
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070213/2072673d/attachment.htm>
