[MPICH] configuting mpich2-1.0.5p2 problems to be used with Totalview 8.0.2-0 later
Manal Helal manalorama at gmail.com
Sun Feb 11 23:59:32 CST 2007
Hello
I appreciate any help I can get on this issue. I am trying to install the
mpich2-1.0.5p2 because Totalview people told me  they have problems running
on previous versions.
I am using the configure command as:
$./configure -prefix=/pathxx/mpich2-install --enable-mpe
--enable-debuginfo --enable-g=dbg,mem,log --enable-threads=multiple
--with-thread-package=pthreads --enable-sharedlibs=gcc | & tee
configure.log
and was advised by Rajeev, to igoner the defaults and use only:
$./configure -prefix=/pathxx/mpich2-install --enable-debuginfo
--enable-g=dbg,mem,log --enable-sharedlibs=gcc | & tee configure.log
both gave me errors: here is what I get early on the configure.log file:
configure: WARNING: you should use --build, --host, --target
configure: WARNING: invalid host type: --enable-debuginfo
and then at the end
checking for virtual path format... VPATH
checking build system type... Invalid configuration
 `--enable-debuginfo': machine `--enable' not recognized
 configure: error:
*/home/mhelal/MyDownloads/mpich2-1.0.5p2/src/mpe2/src/misc/*../.
 ./config.sub
 --enable-debuginfo failed
 configure: error: /bin/sh
 '/home/mhelal/MyDownloads/mpich2-1.0.5p2/src/mpe2/src/misc/configure'
 failed for src/misc
 configure: error: Configure of src/mpe2 failed!
Thank you very much for your time,
Kind Regards,
Manal Helal
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070212/022834b9/attachment.htm>
