[MPICH] any way to ask nemesis to turn-off and turn of active polling ?
    Darius Buntinas
    buntinas at mcs.anl.gov
    Fri Dec 21 15:27:24 CST 2007
If you have P processors, and you're running P slaves and 1 master, I'm
not sure how you could have P+1 processes running at 100%.  Are you
running one slave per processor, then adding an additional master?
If you have a process waiting in a blocking receive, it will show that
it's using 100% of the CPU if it has its own CPU to run on, but if that
process has to share a CPU with another process that's doing some work,
only then will you see the CPU usage of the waiting process go down.
-d
On 12/17/2007 04:48 PM, chong tan wrote:
> I am running RedHat enterprise 5.  sysctl complains that
> sched_compat_yield is not known for kernel.
> BTW, I run the test, and both master and slaves utilize 100% of CPU.
> any suggestion ?
> thanks
> tan
> ----- Original Message ----
> From: Darius Buntinas <buntinas at mcs.anl.gov>
> To: chong tan <chong_guan_tan at yahoo.com>
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Monday, December 17, 2007 1:23:46 PM
> Subject: Re: [MPICH] any way to ask nemesis to turn-off and turn of
> active polling ?
> On 12/17/2007 01:00 PM, chong tan wrote:
>  > Thanks,
>  > I don;t have root access to the box.  I will see if I can ask sys-admin
>  > to do it.  I am running
>  > Linux snowwhite 2.6.18-8.el5 #1 SMP
>  > DO you know if the broken yield got into this version ?
> I don't know, but you can try the master/slave programs from the
> discussion we had on sched_yield a few months ago:
> Master:
> int main() {
>   while (1) {
>     sched_yield();
>   return 0;
> Slave:
> int main() {
>   while (1);
>   return 0;
> Start 4 slaves first, THEN one master, and check 'top'.  If it shows
> that the master is taking more than 1% or so, you have a kernel with the
> 'broken' yield.
>  > FYI : the 'yield' people said it is not 'broken', it is in fact the
>  > 'right yield'.
> Maybe, but Linus is on my side :-)
> -d
>  > tan
> <mailto:buntinas at mcs.anl.gov>>
> <mailto:chong_guan_tan at yahoo.com>>
>  > Cc: mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>  > Sent: Monday, December 17, 2007 10:50:12 AM
>  > active polling ?
>  > Try setting the processor affinity for the "average" processes (map each
>  > one to its own processor).  If you have a kernel with the "broken"
>  > sched_yield implementations, that may not help.
>  > If you have a "broken" sched_yield implementation, you can try doing
>  > this as root:
>  >  sysctl kernel.sched_compat_yield=1
>  > or
>  >  echo "1">/proc/sys/kernel/sched_compat_yield
>  > -d
>  > On 12/17/2007 11:35 AM, chong tan wrote:
>  >  > Yes, in a very subtle way which has major impact on performance.
> I will
>  >  > try to decribe it a litle here:
>  >  > system has 32G, total image 35G.  Load is a litle offbalance
>  >  > mathematically, 4X dual core, running 5 processes.
>  >  > 4 processes are the same size, each runs on a CPU.  the last
> process is
>  >  > very small, about10% of others, run
>  >  > on a core of one of the CPU.  SO 1 CPU runs 2 procs: average
> (P1)one and
>  >  > light one (P2).
>  >  > All proc do first MPI comm in a fixed algorithmic point.  The 'useful'
>  >  > image is about 29G at that point, and should
>  >  > fit into the physical memory.  P2 get there in a heart beat, then
>  >  > others., followed by P1  which took another 60+ minutes
>  >  > to get there.  If I combine P1 and P2 into 1 process, then I don;t no
>  >  > see this extra delay.
>  >  > tan
>  > <mailto:buntinas at mcs.anl.gov <mailto:buntinas at mcs.anl.gov>>>
>  > <mailto:chong_guan_tan at yahoo.com <mailto:chong_guan_tan at yahoo.com>>>
> <mailto:mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>>
>  >  > Sent: Monday, December 17, 2007 8:02:17 AM
>  >  > active polling ?
>  >  > No, there's no way to do that.  Even MPI_Barrier will do active
> polling.
>  >  > Are you having issues where an MPI process that is waiting in a
> blocking
>  >  > call is taking CPU time away from other processes?
>  >  > -d
>  >  > On 12/14/2007 04:53 PM, chong tan wrote:
>  >  >  > My issue is like this :
>  >  >  > among all the processess, some will get to the point of first MPI
>  >  >  > communication points faster than
>  >  >  > than other.  Is there a way that I tell nemesis to start
> without doing
>  >  >  > active polling, and then turn
>  >  >  > on active polling with some function ?
>  >  >  > Or should I just use MPI_Barrier() on that ?
>  >  >  > thanks
>  >  >  > tan
>  >  >  > Be a better friend, newshound, and know-it-all with Yahoo!
> Mobile. Try
>  >  >  > it now.
> <http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
>  >  > Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try
>  >  > it now.
>  > it now.
> it now.
