[MPICH] mpiexec -machinefile option in 1.0.6
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Dec 10 15:47:05 CST 2007
 Did you try specifying the -machinefile option for each of the executables
(mpiexec -l -machinefile mf.txt -n 1 server.exe : -machinefile mf.txt -n 4
client.exe)
 Can you run cpi.exe using the machinefile option ?
(mpiexec -machinefile mf.txt -n 4 cpi.exe)
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Vlad Branzoi
Sent: Monday, December 10, 2007 1:25 PM
Subject: [MPICH] mpiexec -machinefile option in 1.0.6
Has anyone else noticed that the -machinefile option for mpiexec no longer
works ? At least this seems to be the case for me under WinXP with 1.0.6p1.
No matter what is in the machinefile the mpiexec ignores it and does it's
own thing.
For example:
machinefile mf.txt:
hosta:1
hostb:8
Try to run with:
mpiexec -l -machinefile mf.txt -n 1 server.exe : -n 4 client.exe
will try to run everything on the local machine.
Is this a known bug ? Is there a workaround ?
Vlad
