[MPICH] Question about independent IO
    Christina Patrick
    christina.subscribes at gmail.com
    Thu Dec  6 17:22:06 CST 2007
Hi Everybody,
I was reading a paper:
http://www.hdfgroup.uiuc.edu/RFC/HDF5/coll_ind/coll_ind_dd6.pdf
which compares the performance of independent IO and collective IO.
The paper mentions that using the function MPI_File_set_view() and use
independent IO functions such as MPI_File_write()/MPI_File_write_at(),
you are actually using certain optimizations such as data sieving
along with the independent IO?
I wanted to know if that is the case. I wrote a program that uses
MPI_File_set_view() along with MPI_File_write_at(). Does this program
use any kind of optimization?
I would appreciate if you could answer my question,
Christina.
