[MPICH] WRF and MPICH2
Scott Atchley
atchley at myri.com
Fri Aug 17 14:28:55 CDT 2007
On Aug 17, 2007, at 2:19 PM, Brian Dobbins wrote:
> Hi Scott,
> I'm sure you'll get a more knowledgeable response from someone
> else, but as a quick check, are you including a local 'mpif.h' from
> a different MPI distribution? I've gotten this error that way once
> before. Chances are that's not it, but it's something I always
> check now when porting apps from one system to another. ;)
> Cheers,
> - Brian
Hi Brian,
Thanks for the reply.
I cd'd to the mpich2 directory and grep'd for mpif.h in both
config.log and config.status and I see:
% grep mpif.h * | grep -E "config\."
config.log:config.status:1040: creating src/binding/f77/mpif.h
config.status:config_files=" Makefile src/Makefile src/include/
Makefile src/include/mpichtimer.h src/binding/Makefile src/binding/
cxx/Makefile src/binding/cxx/mpicxx.h src/binding/f77/Makefile src/
binding/f77/mpif.h src/binding/f77/setbotf.f src/binding/f90/Makefile
src/binding/f90/mpi_sizeofs.f90 src/env/mpicc src/env/mpicc.conf src/
env/mpicc.bash src/env/mpicxx src/env/mpicxx.conf src/env/mpicxx.bash
src/env/mpif77 src/env/mpif77.conf src/env/mpif77.bash src/env/mpif90
src/env/mpif90.conf src/env/mpif90.bash src/env/mpich2version src/env/
parkill src/env/Makefile src/util/createshlib src/mpi/Makefile src/
mpi/attr/Makefile src/mpi/coll/Makefile src/mpi/comm/Makefile src/mpi/
datatype/Makefile src/mpi/debugger/Makefile src/mpi/errhan/Makefile
src/mpi/group/Makefile src/mpi/init/Makefile src/mpi/misc/Makefile
src/mpi/pt2pt/Makefile src/mpi/rma/Makefile src/mpi/spawn/Makefile
src/mpi/timer/Makefile src/mpi/topo/Makefile src/mpid/Makefile src/
mpid/common/Makefile src/mpid/common/datatype/Makefile src/mpid/
common/locks/Makefile src/pm/Makefile src/pmi/Makefile src/nameserv/
Makefile src/nameserv/file/Makefile src/nameserv/mpd/Makefile src/
nameserv/pmi/Makefile src/nameserv/test/Makefile src/util/Makefile
src/util/info/Makefile src/util/instrm/Makefile src/util/thread/
Makefile src/util/thread/mpe_thread.h src/util/mem/Makefile src/util/
msgs/Makefile src/util/param/Makefile src/util/dbg/Makefile src/util/
dbg/getfuncstack src/util/osserv/Makefile src/include/mpi.h test/
Makefile test/util/Makefile test/basic/Makefile test/commands/
Makefile test/commands/cmdtests test/mpid/Makefile test/mpid/ch3/
Makefile examples/Makefile examples/f77/Makefile examples/f90/
Makefile examples/cxx/Makefile src/util/logging/Makefile src/util/
logging/common/Makefile doc/Makefile doc/mansrc/Makefile doc/mansrc/
createhtmlindex doc/refman/Makefile doc/installguide/Makefile doc/
userguide/Makefile doc/logging/Makefile doc/design/Makefile doc/smpd/
Makefile doc/windev/Makefile"
config.status: "src/binding/f77/mpif.h" )
CONFIG_FILES="$CONFIG_FILES src/binding/f77/mpif.h" ;;
config.status: sed -e 's/^C/\!/g' src/binding/f77/mpif.h > src/
include/mpif.h
config.status: cp src/include/mpif.h src/binding/f77/mpif.h
config.status: cp src/binding/f77/mpif.h src/include
It seems like it is getting the right one.
Scott
