[MPICH] question about MPI-IO Read_all
Wei-keng Liao wkliao at ece.northwestern.edu
Thu Apr 26 14:56:52 CDT 2007
Yes, if the hindexed datatype "describes" the entire amount of data you
want to write, count is 1. In general, one can also use count=2, 3...
That will just write multiple of hindexed datatypes from the I/O buffer.
Wei-keng
On Thu, 26 Apr 2007, Russell L. Carter wrote:
> Ok, very good Wei-keng, one more question.  This is exactly
> what I wanted to know, thanks for addressing it.
> Wei-keng Liao wrote:
>> The data amount to be read/written by an MPI process in a
>> Read_all()/Write_all() is the "count" multiplies the size of the buffer
>> datatype. Therefore, the read/write amount can still be larger than 2GB
>> when integer "count" is less than 2^32. Note that the data amount one can
>> read/write is determined by these two arguments, not the fileview.
>> Hope this helps.
> So if I use say an hindexed datatype for the Read_all, is the count just
> '1'?
> Thanks,
> Russell
>> Wei-keng
