[MPICH] question about MPI-IO Read_all
Rajeev Thakur
thakur at mcs.anl.gov
Thu Apr 26 08:58:47 CDT 2007
The 2 GB limit we are talking about does not apply to the file size. Files
can be larger than that if your file system supports large files. The offset
in the file is of type MPI_Offset, which can be a 64-bit quantity if your
implementation supports it.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Peter Diamessis
> Sent: Wednesday, April 25, 2007 10:42 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] question about MPI-IO Read_all
> Hi folks,
> If I may just comment that this is a very interesting topic.
> I ran into a similar situation when using MPI_WRITE_ALL &
> MPI_READ_ALL to output/read-in non-contiguous 3-D data
> in my CFD solver. The "global" size of the binary file was
> approximately
> 10Gb consisting of 20 3-D variables. I would encounter errors
> when trying
> to output all 20 fields in one file. I then broke the file
> down into 10 files with
> 2 fields each, with approximate file-size equal to 1.2 Gb.
> Then everything
> worked smoothly. I'm wondering if this a similar issue to
> what Russell has
> been pointing out ?
> Sincerely,
> Pete Diamessis
> From: "Rajeev Thakur" <thakur at mcs.anl.gov>
> To: "'Russell L. Carter'" <rcarter at esturion.net>;
> <mpich-discuss at mcs.anl.gov>
> Sent: Wednesday, April 25, 2007 10:19 PM
> Subject: RE: [MPICH] question about MPI-IO Read_all
> > 2^31 is 2 Gbytes. If you are reading 2 GB per process with a single
> > Read_all, you are already doing quite well
> performance-wise. If you want to
> > read more than that you can create a derived datatype of
> say 10 contiguous
> > bytes and pass that as the datatype to Read_all. That would
> give you 20 GB.
> > You read even more by using 100 or 1000 instead of 10.
> > In practice, you might encounter some errors, because the MPI-IO
> > implementation internally may use some types that are
> 32-bit, not expecting
> > anyone to read larger than that with a single call. So try
> it once, and if
> > it doesn't work, read in 2GB chunks.
> > Rajeev
> >> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Russell
> >> L. Carter
> >> Sent: Wednesday, April 25, 2007 6:33 PM
> >> Subject: [MPICH] question about MPI-IO Read_all
> >> Hi,
> >> I have a question about the amount of data it is possible to read
> >> using MPI::Create_hindex with a fundamental type of MPI::BYTE, and
> >> MPI::File::Read_all.
> >> Following the discussion about irregularly distributed
> arras beginning
> >> on p. 78 of "Using MPI-2", I want to read my data by doing this:
> >> double *buf = ...;
> >> int count, bufsize = ...;
> >> MPI::Offset offset = ...;
> >> MPI::File f = MPI::File::Open(...);
> >> MPI::Datatype filetype(MPI::BYTE);
> >> filetype.Create_hindexed(count, blocks, displacements);
> >> f.Set_view(offset, MPI::BYTE, filetype, "native", info_);
> >> f.Read_all(buf, bufsize, MPI::BYTE);
> >> What I a curious about is the amount of data that can
> >> be read with Read_all. Since bufsize is an int, then
> >> that would seem to imply that the maximum Read_all (per node)
> >> is 2^31. Which in bytes, is not gigantic.
> >> Is there some other technique I can use to increase the amount
> >> of data I can Read_all at one time? I have different sized
> >> data interspersed, so I can't offset by a larger fundamental
> >> type. My arrays are not contiguous in the fortran calling program,
> >> and are of int and 4 or 8 byte reals. If I use a Create_struct
> >> to make a filetype that I use to Set_view, doesn't this have
> >> the same read size limitation? Only now it is for all the
> >> arrays in the struct. Hopefully I am missing something.
> >> Thanks,
> >> Russell
