[MPICH] MPI-IO, reading in c++ from fortran generated file
Russell L. Carter
rcarter at esturion.net
Mon Apr 23 17:16:50 CDT 2007
Hopefully this is a nice stupid question. I've got a
a binary (unformatted) fortran file. It's first entry
is a 32 bit int, which I can successfully read with
a simple fortran read into an integer*4 value. I'm
on debian x86_64, using ifort, and I set the environment
variable F_UFMTENDIAN=little when generating and reading
just to be sure that the file is little endian.
Then, assuming nzones is a valid int*, the following
snippet:
MPI::File f = MPI::File::Open(MPI::COMM_WORLD, fname,
MPI::MODE_RDONLY, MPI::INFO_NULL);
file.Read(nzones, 1, MPI_INT, status);
cerr << *nzones;
prints out '4', but the correct value is '1'.
Any clues?
Thanks!
Russell
