[MPICH] But who is the best between the intercommunicator and intracommunicator?
Ashley Pittman
ashley at quadrics.com
Mon Sep 18 08:35:14 CDT 2006
On Fri, 2006-09-15 at 17:40 +0100, Eng. A.A. Isola wrote:
> I have a simple question for you...
> Is better use an
> intercommunicator with Send/Recv or Bcast...
> or is better use the
> MPI_Intercomm_merge and to use the Send/Recv or Bcast inside the new
> intracommunicator created?
> I talk about the performance...is more
> faster the inter or the intracommunicator?
> Do they have the same
> performance?The same speed?
As a general piece of advice if you don't know that you need to use a
intracommunucator you don't need to use one, they are mostly for corner
cases where a intercommunicator isn't avaliable.
Stick to intercommunicators.
Ashley,
