[MPICH] About Visual Studio 2005.
David Ashton
ashton at mcs.anl.gov
Tue Sep 5 19:02:32 CDT 2006
Bruno,
It worked fine for me. I did the following:
1) Create an empty console project called soma in Visual Studio 2005
2) Create a source file, soma.c, and add your code
3) Set the include paths and library paths to MPICH2\include and
MPICH2\lib and link with mpi.lib
4) Compile the Debug target
5) Exit Visual Studio
6) Bring up a Visual Studio 2005 command prompt
7) change into the soma\Debug directory
8) run setmpi2.bat 0 2
9) run devenv.exe soma.exe
10) Bring up another Visual Studio 2005 command prompt
11) change into the soma\Debug directory
12) run setmpi2.bat 1 2
13) run devenv.exe soma.exe
14) At this point I have two debuggers running
15) In the first debugger I hit F10 and start stepping through the code
until I try to step over MPI_Init
16) I move to the second debugger and hit F10 and step through the code
until I step over MPI_Init
17) At this point both debuggers are stepping through the code and I can
do whatever I want
-David Ashton
_____
From: Bruno Simioni [mailto:brunosimioni at gmail.com]
Sent: Tuesday, September 05, 2006 1:08 PM
To: David Ashton
Subject: Re: [MPICH] About Visual Studio 2005.
Man, that is so hard!
I'm trying that.
I create a file, with this code:
#include <mpi.h>
#include <stdio.h>
int main(int argc, char *argv[]){
int soma = 0, s= 0, myid, numprocs, i, v[100];
MPI_Init(&argc, &argv);
MPI_Comm_rank (MPI_COMM_WORLD, &myid);
MPI_Comm_size(MPI_COMM_WORLD, &numprocs);
if(myid ==0)
for(i = 0; i < 100; i++)
v[i] = i+1;
MPI_Bcast(v, 100, MPI_INT, 0, MPI_COMM_WORLD);
soma = 0;
for (i = myid; i< 100; i += numprocs)
soma += v[i];
printf ("Resultado parcial no processador: %d = %d \n", myid, soma);
MPI_Reduce(&soma, &s, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD);
if(myid == 0)
printf("Soma final = %d\n", s);
MPI_Finalize();
return(0);
That is called soma.c .
Then I starte the visual studio 2005 and created an empty win32 console
application at file > new project > win32 console application > next > empty
project > finish.
So, after read and execute the windows developer's manual instruction, at
mpich2 web site, I tried to execute the debugger, pressing F10.
And, it just didn't run. An console is open and bring the message that was
impossible to create an process. Acess Denied.
So, what i'm I doing wrong? Why the debbuger doesn't run?
The method using setmpi2.bat runs, but i want more than that.
Thanks.
Bruno.
On 9/5/06, David Ashton < <mailto:ashton at mcs.anl.gov> ashton at mcs.anl.gov>
wrote:
Bruno,
If you are getting assembly code stepping through your own code then you
need to create debugging information for your project. This is documented
in the Visual Studio help pages. If you want to step through the MPICH2
source code then you will have to download the source code distribution of
MPICH2 1.0.3 and compile it yourself. This shouldn't be necessary since you
shouldn't need to debug the MPI functions.
-David Ashton
_____
Sent: Monday, September 04, 2006 9:13 PM
To: David Ashton
Hey David!
So, I abtain sucess trying to debug on command prompt, using the batch file
to setup environment variables. But I'm looking for a sofisticated debbuger.
I tried to use the debugger os visual studio, by command prompt, but it
returns the assembler code just. I need more than that.
What about the referenced mpi debugger included on visual studio 2005? do
you know how can i use that? do you know if it shows the content of
procedures, in C code? like an usual debugger?
Thanks.
Bruno!
On 9/1/06, David Ashton <ashton at mcs.anl.gov> wrote:
Download the Windows Developer's Guide from the MPICH2 web page
Documentation section.
http://www.mcs.anl.gov/mpi/mpich2
Go to the section Runtime environment :: Debugging jobs by starting them
manually. Follow the instructions in that section. The idea is that you
will bring up a command prompt for each process in your job. You will
execute the script provided in the manual to set up the environment
variables. Then you can run each process in each command prompt by hand.
You can also start a debugger for any or all of the processes by starting
the debugger from the command prompt of the process you want to debug. You
have to start the debugger from the command prompt so that it inherits the
environment variables necessary to run the process.
-David Ashton
_____
From: Bruno Simioni [mailto: brunosimioni at gmail.com]
Sent: Friday, September 01, 2006 2:55 PM
To: David Ashton
Hey David!
Yes, i'm trying to attach an debugger. The debugger is included in Visual
Studio 2005. I tried to use -localroot and -localonly in Mpiexec command, in
project properties at Visual Studio, but I've got the same answer - Access
Denied.
So, why can't I debbug my mpi app? what's wrong with Visual Studio?
And, enviroment variables, that is referenced in the manual, you reffers
about mpich2 manual? and variables of smpd process?
Should I enter commands at ms-dos prompt, in windows? that's it?
I'm totally lost! hehe..
Thanks!
Bruno.
That's why I said "may" need to add the -nodbg option. In your case don't
add this option.
Since you are getting an "Access is denied" error I assume you are trying to
attach a debugger to one of the processes started by the smpd process
manager. If you want to debug the first process, process zero, you can add
-localroot to the mpiexec command. If you want to debug a process other
than the root process and it is ok to run all the processes on the local
machine you can add the -localonly option to mpiexec.
If you are unable to attach to a running process using either the -localroot
or -localonly options then you will have to use the command prompt options
described in the manual.
-David Ashton
_____
Sent: Friday, September 01, 2006 2:32 PM
To: David Ashton
Hey David,
That's the answer: unknow option: -nodbg.
I'm using mpich2 1.0.3. That's version includes that option?
Thanks!
Bruno.
Bruno Simioni,
If you want to attach to a running job you may need to add -nodbg to the
mpiexec command.
Example: mpiexec -nodbg -n 4 myapp.exe
This option tells mpiexec to not debug the application so you can attach
your own debugger.
If you want to start the application from within Visual Studio 2005 there
are two options. You can set up the environment for each process in a
command prompt and then start an instance of Visual Studio for each process.
The environment variables are described in the manual.
Or you can use the parallel debugger provided in some versions of Visual
Studio.
http://msdn2.microsoft.com/en-us/library/ms164731.aspx
-David Ashton
_____
<mailto:owner-mpich-discuss at mcs.anl.gov> owner-mpich-discuss at mcs.anl.gov]
On Behalf Of Bruno Simioni
Sent: Friday, September 01, 2006 1:46 PM
Subject: [MPICH] About Visual Studio 2005.
Hi everybody!
A time ago I sent a email about an error reported on Visual Studio 2005
debugger. I was tring to debug an MPI application.
That is a simple test, just to see what happens on each process.
That's the code:
// Somas parciais
#include <mpi.h>
#include <stdio.h>
if(myid ==0)
v[i] = i+1;
soma = 0;
for (i = myid; i< 100; i += numprocs )
soma += v[i];
if(myid == 0)
MPI_Finalize();
return(0);
It returns the addition of 100 numbers. The charge is shared equally on each
process.
But when I try debbug that, the console returns:
soma.exe on 'bruno' failed, error 5 - Access Denied.
Windows do not permit Visual Studio create process.
Anybody has experimented the same error?
Thanks!
Bruno Simioni
Bacharelado em Ciências da Computação
Universidade Estadual Paulista - Unesp - Rio Claro / São Paulo
14 - 9753-4380
Bruno Simioni
14 - 9753-4380
Bruno Simioni
14 - 9753-4380
Bruno Simioni
14 - 9753-4380
Bruno Simioni
14 - 9753-4380
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20060905/aed14f81/attachment.htm>
