[MPICH] The jumpshot-4 doesn't run on Fedora Core 4 workstation.
Anthony Chan chan at mcs.anl.gov
Tue Sep 5 10:31:35 CDT 2006
The reason of your jumpshot installation isn't working is that you are
using gcc's version of java virtual machine (noticed the error message is
from libgcj.so) which has most AWT support except Java2D.  What it means
is that gcc's JVM can run non-GUI related java code within slog2sdk but
not jumpshot.  If you want Jumpshot to run, you need to install either
SUN's or IBM's java.  Then rerun mpich2's installation procedure, i.e.
cd <mpich2-1.0.4p1-build-dir>
make distclean
<mpich2-1.0.4p1>/configure .... --with-java=<j2sdk-1.4.2-install-dir> ...
make
make install
A.Chan
On Tue, 5 Sep 2006, Chang wrote:
> Hello,
> The jumpshot( installed with MPICH2-1.0.4p1) doesn't run on my Fedora Core 4 workstation(full installation).
> How to slove the problem?
> thank you
> the messages were shown as follows:
> [lab at localhost ~]$ jumpshot cpilog.slog2
> GUI_LIBDIR is set. GUI_LIBDIR = /home/lab/mpich2-install//lib
> Java is version 1.4.2.
> Starting the SLOG-2 Display Program .....
> Jumpshot-4 setup file : /home/lab/.jumpshot4.conf
> Creating Jumpshot-4 setup file ...
> Finalize Parameters:
> Y_AXIS_ROOT_LABEL = SLOG-2
> INIT_SLOG2_LEVEL_READ = 4
> AUTO_WINDOWS_LOCATION = true
> SCREEN_HEIGHT_RATIO = 0.5
> TIME_SCROLL_UNIT_RATIO = 0.01
> Y_AXIS_ROOT_VISIBLE = true
> ACTIVE_REFRESH = false
> ROW_RESIZE_MODE = Row
> BACKGROUND_COLOR = black
> STATE_HEIGHT_FACTOR = 0.9
> NESTING_HEIGHT_FACTOR = 0.8
> ARROW_ANTIALIASING = default
> MIN_WIDTH_TO_DRAG = 4
> CLICK_RADIUS_TO_LINE = 3
> LEFTCLICK_INSTANT_ZOOM = true
> STATE_BORDER = ColorRaised
> ARROW_HEAD_LENGTH = 10
> ARROW_HEAD_WIDTH = 6
> EVENT_BASE_WIDTH = 8
> PREVIEW_STATE_DISPLAY = CumulativeExclusionRatio
> PREVIEW_STATE_BORDER = ColorXOR
> PREVIEW_STATE_BORDER_W = 3
> PREVIEW_STATE_BORDER_H = 0
> PREVIEW_STATE_LEGEND_H = 2
> PREVIEW_ARROW_LOG_BASE = 5
> SEARCH_ARROW_LENGTH = 20
> SEARCH_FRAME_THICKNESS = 3
> SEARCHED_OBJECT_ON_TOP = false
> HISTOGRAM_ZERO_ORIGIN = true
> SUMMARY_STATE_BORDER = ColorRaised
> SUMMARY_ARROW_LOG_BASE = 5
> LEGEND_PREVIEW_ORDER = true
> LEGEND_TOPOLOGY_ORDER = true
> Initialize Parameters:
> Exception during event dispatch:
> java.lang.ClassCastException: java.awt.Graphics2D
>    at viewer.legends.CategoryIcon.paintStateIcon(java.awt.Graphics, int, int) (Unknown Source)
>    at viewer.legends.CategoryIcon.paintIcon(java.awt.Component, java.awt.Graphics, int, int) (Unknown Source)
>    at javax.swing.plaf.basic.BasicLabelUI.paint(java.awt.Graphics, javax.swing.JComponent) (/usr/lib/libgcj.so.6.0.0)
>    at javax.swing.plaf.ComponentUI.update(java.awt.Graphics, javax.swing.JComponent) (/usr/lib/libgcj.so.6.0.0)
>    at javax.swing.JComponent.paintComponent(java.awt.Graphics) (/usr/lib/libgcj.so.6.0.0)
>    at javax.swing.JComponent.paint(java.awt.Graphics) (/usr/lib/libgcj.so.6.0.0)   at javax.swing.plaf.basic.BasicTableUI.paint(java.awt.Graphics, javax.swing.JComponent) (/usr/lib/libgcj.so.6.0.0)
>    at javax.swing.JComponent.paint(java.awt.Graphics) (/usr/lib/libgcj.so.6.0.0)   at javax.swing.plaf.basic.BasicViewportUI.paintSimple(java.awt.Graphics, javax.swing.JViewport, java.awt.Component, java.awt.Point, java.awt.Rectangle, java.awt.Rectangle) (/usr/lib/libgcj.so.6.0.0)
>    at javax.swing.plaf.basic.BasicViewportUI.paint(java.awt.Graphics, javax.swing.JComponent) (/usr/lib/libgcj.so.6.0.0)
>    at javax.swing.JViewport.paint(java.awt.Graphics) (/usr/lib/libgcj.so.6.0.0)
>    at java.awt.Container$GfxPaintVisitor.visit(java.awt.Component, java.awt.Graphics) (/usr/lib/libgcj.so.6.0.0)
>    at java.awt.Container.visitChild(java.awt.Graphics, java.awt.Container$GfxVisitor, java.awt.Component) (/usr/lib/libgcj.so.6.0.0)
>    at java.awt.Container.visitChildren(java.awt.Graphics, java.awt.Container$GfxVisitor, boolean) (/usr/lib/libgcj.so.6.0.0)
>    at java.awt.Container.paint(java.awt.Graphics) (/usr/lib/libgcj.so.6.0.0)
>    at javax.swing.JComponent.paintChildren(java.awt.Graphics) (/usr/lib/libgcj.so.6.0.0)
>    at javax.swing.JComponent.paint(java.awt.Graphics) (/usr/lib/libgcj.so.6.0.0)   at java.awt.Container$GfxPaintVisitor.visit(java.awt.Component, java.awt.Graphics) (/usr/lib/libgcj.so.6.0.0)
>    at javax.swing.JComponent.paintImmediately(java.awt.Rectangle) (/usr/lib/libgcj.so.6.0.0)
>    at javax.swing.RepaintManager.paintDirtyRegions() (/usr/lib/libgcj.so.6.0.0)
>    at javax.swing.RepaintManager$RepaintWorker.run() (/usr/lib/libgcj.so.6.0.0)
>    at java.awt.event.InvocationEvent.dispatch() (/usr/lib/libgcj.so.6.0.0)
>    at java.awt.EventQueue.dispatchEvent(java.awt.AWTEvent) (/usr/lib/libgcj.so.6.0.0)
>    at java.awt.EventDispatchThread.run() (/usr/lib/libgcj.so.6.0.0)
>    at .GC_start_routine (/usr/lib/libgcj.so.6.0.0)
>    at .__clone (/lib/libc-2.3.5.so)
>    at javax.swing.JFrame.update(java.awt.Graphics) (/usr/lib/libgcj.so.6.0.0)
>    at gnu.java.awt.peer.gtk.GtkComponentPeer.handleEvent(java.awt.AWTEvent) (/usr/lib/lib-gnu-java-awt-peer-gtk.so.6.0.0)
>    at java.awt.Component.dispatchEvent(java.awt.AWTEvent) (/usr/lib/libgcj.so.6.0.0)
> (.:3106): GLib-GObject-WARNING **: invalid uninstantiatable type `<unknown>' in cast to `GtkWindow'
> (.:3106): Gtk-CRITICAL **: gtk_window_set_transient_for: assertion `parent == NULL || GTK_IS_WINDOW (parent)' failed
> (.:3106): GLib-GObject-WARNING **: invalid uninstantiatable type `<unknown>' in cast to `GtkWidget'
> (.:3106): Gtk-CRITICAL **: gtk_widget_hide: assertion `GTK_IS_WIDGET (widget)' failed
> (.:3106): Gtk-CRITICAL **: gtk_widget_destroy: assertion `GTK_IS_WIDGET (widget)' failed
