[MPICH] compilation under VS2005 - add adsiid.lib while linking
Jayesh Krishna jayesh at mcs.anl.gov
Tue Oct 17 09:57:49 CDT 2006
 You will not have to comment out references to IID_IDirectoryObject,
IID_IADsContainer,IID_IDirectorySearch in smpd_ad.cpp.
  Have you included adsiid.lib while linking ? If you still have problems
with linking please send us an e-mail with the error and the list of
libraries that you include while linking.
 Jayesh Krishna
 Argonne National Laboratory
 Mathematics and Computer Science
 Email: jayesh at mcs.anl.gov
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of devteam
Sent: Tuesday, October 17, 2006 8:44 AM
To: Jayesh Krishna; mpich-discuss at mcs.anl.gov
Cc: mpich2-maint at mcs.anl.gov
Subject: Re: [MPICH] compilation under VS2005 - get wspiapi.h out of extern
"C" block
I finally almost got it.
I used mpich2.1.0.2p1 (there is no --vs05 option for winconfigure in the
mpich2.1.0.4p1 version).
I had to do several things:
In smpd_util project:
    * Add smpd_job.c to the project
    * add MPICH_IGNORE_CXX_SEEK compilation directive
In mpidu_sock.h:
add CPLUSPLUS_END before #include "mpidu_socki.h and CPLUSPLUS_BEGIN just
after
In mpiexec project (same in smpd project) link also with:
    * activeds.lib and netapi32.lib
Then mpiexec compiles and link and there remains undefined symbols related
to activeDir stuff.
In order to generate mpiexec.exe I had to comment out references to
IID_IDirectoryObject, IID_IADsContainer,IID_IDirectorySearch in smpd_ad.cpp
(but not in smpd_adreg.cpp).
Andres
----- Original Message -----
From: Jayesh  <mailto:jayesh at mcs.anl.gov> Krishna
Sent: Monday, October 16, 2006 8:34 PM
Subject: FW: [MPICH] compilation under VS2005 - get wspiapi.h out of extern
"C" block
 In VS 2005 there are C++ templates in some of the header files (VS 2003 did
not have them). So these header files should be considered as C++ header
files rather than C header files and one has to make sure that these C++
header files are outside the extern "C" {} blocks in the code.
 One such C++ header file is <wspiapi.h>. If you make sure that this header
file is not included in an extern "C" {} block you should be able to get
past this compilation error (Please note that this header file may be
included by some other header files in an extern "C" block. To know the list
of header files included by your source code and the order in which they are
included enable "show includes" in Visual studio.).
 This code works for Visual Studio 2003 and we will be changing the code to
make it compatible with VS 2005 in our next release.
 Please let us know if this works for you.
 Jayesh Krishna
  _____
Sent: Monday, October 16, 2006 3:23 AM
Subject: [MPICH] compilation under VS2005
Hello everyone,
We've trying to compile mpich2 under VS2005, with no success yet... here is
the error message.
Any suggestions on what's going wrong ?
Thank you,
Andres
in wsiapi.h
#if !defined(_WSPIAPI_COUNTOF)
#if !defined(__cplusplus)
#define _WSPIAPI_COUNTOF(_Array) (sizeof(_Array) / sizeof(_Array[0]))
#else
template <typename __CountofType, size_t _N>
char (&__wspiapi_countof_helper(__CountofType (&_Array)[_N]))[_N];
#define _WSPIAPI_COUNTOF(_Array) sizeof(__wspiapi_countof_helper(_Array))
#endif
#endif
error message:
1>------ Build started: Project: smpd_util, Configuration: Debug Win32
1>Compiling...
1>smpd_adreg.cpp
1>c:\program files\microsoft visual studio
8\vc\platformsdk\include\wspiapi.h(44) : error C2894: templates cannot be
declared to have 'C' linkage
1>Build log was saved at
"file://d:\DEVELOPPEMENTS\MPICH2\Argonne\mpich2-1.0.2p1\mpich2-1.0.2p1\src\p
m\smpd\smpd_utilDebug\BuildLog.htm"
1>smpd_util - 1 error(s), 0 warning(s)
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20061017/6100cd90/attachment.htm>
