[MPICH] standard input limited to 4096 bytes?
    Martin Kleinschmidt
    mk at theochem.uni-duesseldorf.de
    Tue Oct 17 09:56:02 CDT 2006
I'm having problems with standard input.
the following program:
      program  test
      include 'mpif.h'
      integer myid, nproc
      write(*,*) '0'
      call MPI_init(MPIerr)
      write(*,*) '0a'
      call MPI_comm_rank(MPI_comm_world,myid, MPIerr)
      write(*,*) '0b'
      call MPI_comm_size(MPI_comm_world,nproc,MPIerr)
      write(*,*) '0c'
      end
runs correctly when started with
mpiexec -n2 ./a.out < input_file_smaller_than_4097_bytes
but hangs in call MPI_init when called with
mpiexec -n2 ./a.out < input_file_larger_than_4096_bytes
note that the program does NOT access standard input!
I'm using mpich2-1.0.4p1, intel compilers 9.x, fedora core2.
Is this a general problem of mpich?
Is there any solution?
In my "real" program, I regularly need standard input from files larger
than 4096 bytes.
thanks!
   ...martin
