[MPICH] "failed to ping mpd on "
Ralph Butler
rbutler at mtsu.edu
Mon May 22 12:23:59 CDT 2006
There is a patch to mpd.py that you may need to apply (attached).
However, that may not be your problem if this is a fresh install.
Before using mpdboot, the install guide suggests using mpdcheck
in a variety of ways to verify that the host config is OK. The
Troubleshooting
portion of the guide takes you through those steps.
--ralph
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20060522/d00a36ef/attachment.obj>
On May 22, 2006, at 10:04 AM, hicham wrote:
> Hello
> I'm a newbie to this mailing list and to mpich2
> I've installed mpich on 2 pc's ( MachineMPI2 and 3 ) on Fedora ,
> but running
> "mpdboot -n 2 -f mpd.hosts" gives me :
> mpdboot_MachineMPI2 (handle_mpd_output 359): failed to ping mpd on
> MachineMPI3; recvd output={}
> Thanks for your help
> hicham
