[MPICH] FW: Mpich2 submission question.
Rajeev Thakur
thakur at mcs.anl.gov
Thu Mar 9 11:50:27 CST 2006
That might be a property of the application you are running. If you run some
other MPI program, such as the examples and tests in MPICH2, you might find
that to not be the case.
Rajeev
_____
Sent: Thursday, March 09, 2006 10:11 AM
To: 'Rajeev Thakur'
Cc: mpich-discuss at mcs.anl.gov
Subject: RE: [MPICH] FW: Mpich2 submission question.
Sure,
This may be specific to the program I'm running, MCNP, but when you run
mpiexec -n 2 mcnp5
what you see is that two processes are created on the cluster. The first
process accumulates no cpu, the second runs normally. The result is
accurate.
As you continue to add CPUs nothing changes -- the first process is always
"idle". If you specifiy -n 1 however, the first process is "active".
Any thoughts?
Simons
-----Original Message-----
Sent: March 7, 2006 5:51 PM
To: galtons at aecl.ca
Can you explain what you mean with an example? For example, if you are
running the cpi example from the examples directory, with "mpiexec -n 2 cpi"
Rajeev
> From: "Galton, Simon" <galtons at aecl.ca>
> Subject: Mpich2 submission question.
> Date: Tue, 7 Mar 2006 09:46:02 -0500
> Howdy, folks.
> I've been scouring the mpich2 documentation, and I've read over the
> source code, and I seem to be missing something, somewhere... :)
> I notice that when you submit an mpich2 job, the first process
> accumulates no CPU (unless you submit a 1-cpu job). I expect it's
> just a control process.
> Is there anything I can do to make this an "active" process?
> Simon
CONFIDENTIAL AND PRIVILEGED INFORMATION NOTICE
This e-mail, and any attachments, may contain information that
is confidential, subject to copyright, or exempt from disclosure.
Any unauthorized review, disclosure, retransmission,
dissemination or other use of or reliance on this information
may be unlawful and is strictly prohibited.
AVIS D'INFORMATION CONFIDENTIELLE ET PRIVILÉGIÉE
Le présent courriel, et toute pièce jointe, peut contenir de
l'information qui est confidentielle, régie par les droits
d'auteur, ou interdite de divulgation. Tout examen,
divulgation, retransmission, diffusion ou autres utilisations
non autorisées de l'information ou dépendance non autorisée
envers celle-ci peut être illégale et est strictement interdite.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20060309/ba11def4/attachment.htm>
