[MPICH] MPICH2 v1.02 in heterogeneous enviroment
    Rajeev Thakur
    thakur at mcs.anl.gov
    Tue Mar  7 14:33:18 CST 2006
Yes it's definitely planned, but can't give a firm date for when it will
appear in the implementation.
Rajeev
  _____
From: Kenneth Rempe [mailto:kenneth.rempe at studsvikscandpower.com]
Sent: Tuesday, March 07, 2006 2:16 PM
To: Rajeev Thakur
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [MPICH] MPICH2 v1.02 in heterogeneous enviroment
Thanks for the response. I found the following in the MPICH2_1.0.3 release
notes:
- The CH3 device does not presently support heterogeneous communication.
That
  is to say that the processes involved in a job must use the same basic
type
  sizes and format.  The sizes and format are typically determined by the
  processor architecture, although it may also be influenced by compiler
  options.  This device does support the use of different executables (e.g.,
  multiple-program-multiple-data, or MPMD, programming).
Which is just as you stated. Do you know if true heterogeneous support is
planned?
Thanks again.
Ken
Rajeev Thakur wrote:
MPICH2 doesn't yet work in heterogeneous environments. It will work in
heterogeneous environments that really are homogoneous, ie, no differences
in byte ordering, sizes of datatypes, etc.
Rajeev
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Kenneth Rempe
Sent: Monday, March 06, 2006 8:13 AM
Subject: [MPICH] MPICH2 v1.02 in heterogeneous enviroment
I'm using MPICH2 v1.02 with IBM AIX 5.2 and Red Hat Linux. My program
works fine
if I just run on Linux machines or just IBM machines but
fails with the
following message when
trying to run on both IBM and Linux at the same time.
Fatal error in MPI_Comm_spawn: Internal MPI error!, error stack:
MPI_Comm_spawn(128):
MPI_Comm_spawn(cmd="/home/ken/DUKE/Formosa-link/New/FPSIM3/Lin
ux/fpsim3.exe",
argv=2005bc88, maxprocs=1, info=0x9c000000, root=0, MPI_COMM_WORLD,
intercomm=2005b858, errors=2002fff0) failed
MPID_Comm_spawn_multiple(52):
MPIDI_CH3_Comm_spawn_multiple(212):
MPIDI_CH3_Comm_accept(102):
MPIDI_CH3_Progress_wait(209): an error occurred while
handling an event
returned by MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(886): [ch3:sock]
received packet
of unknown type (385875968)
% rank 0 in job 1  ibm6e1_34162   caused collective abort of all ranks
  exit status of rank 0: killed by signal 9
Is it possible to use MPICH2 in a heterogeneous environment?
Thanks.
*** NOTE: soa.com will no longer be used after February 1, 2006, please
change your address book ***
Kenneth R. Rempe                * email:
Studsvik Scandpower, Inc.       *
504 Shoup Avenue Suite #201     * voice:  208-522-4630
Idaho Falls, ID USA 83402-3502  * fax:    208-522-1187
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20060307/70acd641/attachment.htm>
