[MPICH] MPICH2 errorno 11004
    David Ashton
    ashton at mcs.anl.gov
    Fri Jun  9 17:09:12 CDT 2006
Jaspreet Hothi,
The order of your arguments is not correct.  It should be like this:
mpiexec -hosts 2 electra.2.com asterope.2.com cpi.exe
-David Ashton
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Jaspreet Hothi
Sent: Friday, June 09, 2006 8:18 AM
Subject: [MPICH] MPICH2 errorno 11004
Can somebody help me with the following error message
I am using following command to run the example problem cpi.exe in MPICH2
C:\Documents and Settings\Jaspreet>"C:\Program Files\MPICH2\bin\mpiexec.exe"
-hosts 2 "C:\Program Files\MPICH2\examples\cpi.exe" electra.2.com
<http://electra.2.com/>  asterope.2.com <http://asterope.2.com/>
The error I am receiving is as follows:
Unable to connect to 'C:\Program Files\MPICH2\examples\cpi.exe:8676',
sock error: generic socket failure, error stack:
MPIDU_Sock_post_connect(1200): unable to connect to C:\Program
Files\MPICH2\examples\cpi.exe on port 8676, exhausted all endpoints (errno
-1)
MPIDU_Sock_post_connect(1216): gethostbyname failed, The requested name is
valid and was found in the database, but it does not have the correct
associated data being resolved for. (errno 11004)
MPIDU_Sock_post_connect(1216): gethostbyname failed, No such host is known.
(err
no 11001)
The C:\Program Files\MPICH2\examples\  folder is shared on both the
machines.
Thanks
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20060609/b436d5f9/attachment.htm>
