[MPICH] MPICH2 errorno 11004
Jaspreet Hothi jaspreet at alcyon.co.in
Fri Jun 9 09:18:03 CDT 2006
Can somebody help me with the following error message
I am using following command to run the example problem cpi.exe in MPICH2
C:\Documents and Settings\Jaspreet>"C:\Program Files\MPICH2\bin\mpiexec.exe"
-hosts 2 "C:\Program Files\MPICH2\examples\cpi.exe" electra.2.com
asterope.2.com
The error I am receiving is as follows:
Unable to connect to 'C:\Program Files\MPICH2\examples\cpi.exe:8676',
sock error: generic socket failure, error stack:
MPIDU_Sock_post_connect(1200): unable to connect to C:\Program
Files\MPICH2\examples\cpi.exe on port 8676, exhausted all endpoints (errno
-1)
MPIDU_Sock_post_connect(1216): gethostbyname failed, The requested name is
valid and was found in the database, but it does not have the correct
associated data being resolved for. (errno 11004)
MPIDU_Sock_post_connect(1216): gethostbyname failed, No such host is known.
(err
no 11001)
The C:\Program Files\MPICH2\examples\  folder is shared on both the
machines.
Thanks
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20060609/969370c6/attachment.htm>
