[MPICH] Autoconf and MPICH
C B craig.mpich at gmail.com
Fri Jul 7 11:53:32 CDT 2006
Thanks Rjeev,
I've copied it over and ran it in the mpich toplevel directory.  Now it
user at host ~/mpich $ ../../download/autoconf-1.7/autoconf-1.7
configure.in:2019: AC_COMPILE_CHECK was called before AC_AIX
configure.in:2019: AC_TEST_PROGRAM was called before AC_AIX
configure.in:2020: AC_COMPILE_CHECK was called before AC_MINIX
configure.in:2020: AC_TEST_PROGRAM was called before AC_MINIX
Any ideas?
C
On 7/7/06, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
>  You can get autoconf 1.7 from www.mcs.anl.gov/~thakur/autoconf.tar.gz<http://www.mcs.anl.gov/%7Ethakur/autoconf.tar.gz>.
> Let me know after you have copied it over.
> Rajeev
> *From:* owner-mpich-discuss at mcs.anl.gov [mailto:
> owner-mpich-discuss at mcs.anl.gov] *On Behalf Of *C B
> *Sent:* Friday, July 07, 2006 9:24 AM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* [MPICH] Autoconf and MPICH
> Hello,
> I am working with the mpich-1.2.6 build system, and trying to rebuild the
> configure script.  I'm running autoconf version 2.59e (debian), and when I
> run autoconf I get the following error:
> user at host:~/mpich_please_work$ autoconf
> aclocal.m4:414: error: m4_defn: undefined macro: _m4_divert_diversion
> aclocal.m4:414: the top level
> autom4te: /usr/bin/m4 failed with exit status: 1
> I believe that I read somewhere that I should be using an old ( 1.7)
> version of autoconf.  I'm not sure of the validity of this statement, and I
> cannot find a version of autoconf dating back that far to verify it.   Does
> anyone have any suggestions?
> Thanks in advance,
> C
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20060707/a3e4d30e/attachment.htm>
