[MPICH] MPI_Finalize preconditions
    Rajeev Thakur
    thakur at mcs.anl.gov
    Thu Jan 26 17:46:59 CST 2006
If you have called MPI_Isend, you need to call MPI_Wait before calling
Finalize.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Angel Tsankov
> Sent: Thursday, January 26, 2006 5:03 PM
> To: ML: MPICH-discuss post
> Subject: Re: [MPICH] MPI_Finalize preconditions
> OK, I think I need to clarify my question, too. So, let's assume that
> the process has received all incoming messages. It, however, has
> initiated at least one send operation via a call to MPI_Isend or
> MPI_Send_init. However, the process has not explicitly completed any
> of these send operations. Assuming that the program is written
> correctly, i.e. those send operations have matching receive
> operations
> (possibly in other processes), is it safe to call MPI_Finalize right
> after a call to MPI_Barrier( MPI_COMM_WORLD ) has returned?
> I guess it is also a good idea, if Rob explains what he means by "all
> sends have completed".
> > Actually I should clarify that.  If the process has received all
> > incoming messages *and* all sends have completed, then the process
> > is ready to call finalize.
> > Rob
> > Rob Ross wrote:
> >> Hi Angel,
> >> If a given process has received all incoming messages, then that
> >> process is ready to call finalize.  You don't have to perform the
> >> barrier operation; it's just extra overhead.
> >> Regards,
> >> Rob
> >> Angel Tsankov wrote:
> >>> The MPI standard says:
> >>> "The user must ensure that all pending communications involving a
> >>> process completes before the process calls MPI_FINALIZE."
> >>> If each nonblocking receive call has a matching wait call, does a
> >>> call to MPI_Barrier( MPI_COMM_WORLD ) in all processes (and after
> >>> the wait calls) ensure that all communications involving the
> >>> processes have completed?
