[MPICH] mpirun issue on Windows XP
    David Ashton
    ashton at mcs.anl.gov
    Sun Jan 15 22:38:18 CST 2006
Duane,
MPICH.nt.1.2.5 is no longer supported and users should migrate to MPICH2:
http://www.mcs.anl.gov/mpi/mpich2
MPICH.nt.1.2.5 uses a temporary file to communicate between mpirun and the
root process.  There can be sharing and naming issues with this temporary
file.  Try deleting all mpi*.tmp files on your system and then run mpirun
again.
You will get better performance and a more stable startup process if you
switch to MPICH2.
-David Ashton
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Ward, Duane L
Sent: Thursday, January 12, 2006 5:01 PM
Subject: [MPICH] mpirun issue on Windows XP
I am new to mpi and am using mpich.nt.1.2.5 on a machine running Windows
XP Service Pack 2.  The problem I am having is when I execute mpirun I
get the following error message:
./mpi/mpirun -np 2 cpi.exe
Error 32, process 0, host Vertex:
     CreateFile failed: .\mpi3D.tmp
Wait for process 0 to write port to temporary file timed out
I am running everything from a Cygwin Xterm.  Anyone have an idea as to
what might be causing this error?
Duane
