[MPICH] Windows runs error?
David Ashton ashton at mcs.anl.gov
Fri Feb 24 01:49:46 CST 2006
Lu H.Q.
Can you install MPICH2 and re-compile your application or are you required
to use MPICH.NT 1.2.5?  mpich.nt.1.2.5 is no longer being developed and it
is recommended that users upgrade to MPICH2.
http://www.mcs.anl.gov/mpi/mpich2
-David Ashton
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Lu H.Q.
Sent: Thursday, February 23, 2006 8:30 PM
Subject: [MPICH] Windows runs error?
hello ,when i run mpirun in windows (1 cpu and 1computer)
i pass the example "cpi",
mpirun -np 2 cpi
Process 1 on shu-6f3e7f7fb51.
Process 0 on shu-6f3e7f7fb51.
Enter the number of intervals: (0 quits) 23
pi is approximately 3.1417501835074964, Error is 0.0001575299177032
wall clock time = 0.000307
Enter the number of intervals: (0 quits) 43
pi is approximately 3.1416377229963759, Error is 0.0000450694065828
wall clock time = 0.000236
Enter the number of intervals: (0 quits) 22
pi is approximately 3.1417648298813803, Error is 0.0001721762915872
wall clock time = 0.000240
but my owner program "mpi_test" wrong, the error is followed,i want to
know what is reason and how do it
mpirun -np 2 mpi_test
easy_connect(g_sockStopIOSignalSocket, shu-6f3e7f7fb51, 1124) failed,
error 10057
my program  have a input file ,so i run like this below and  meet another
error:
mpirun -np 2 mpi_test <in.melt
easy_connect(g_sockStopIOSignalSocket, shu-6f3e7f7fb51, 1150) failed,
error 10061
if i run the same command may time,i get the same error with different
error number:
easy_connect(g_sockStopIOSignalSocket, shu-6f3e7f7fb51, 1153) failed,
error 10057
easy_connect(g_sockStopIOSignalSocket, shu-6f3e7f7fb51, 1155) failed,
error 10057
Thanks many
