[MPICH] mpich without shared home directories
Goncalo Borges
goncalo at lip.pt
Mon Apr 24 08:51:33 CDT 2006
As I said, I didn't implement that wet. My cluster is integrated in
a world wide grid running Globus which lauches a jobmanager script
everytime a job is submitted. This jobmanager is a wrapper which,
in principle, will copy all the executables to the execution nodes
before running the job (and deletes them at the end). This is how I
intend to do it...
Regarding the library binaries, they are all copied to each one of
the exec machines.
Cheers
Goncalo
On Mon, 24 Apr 2006, David Gunter wrote:
> I am curious about your setup. How do you ensure the executable is pushed out
> to all the execution nodes? And do you run with statically built binaries
> only or do you have a way of making sure the necessary shared libs are
> available on the execution nodes?
> -david
> David Gunter
> CCN-8: HPC Environments: Parallel Tools Team
> Los Alamos National Laboratory
> On Apr 24, 2006, at 5:50 AM, Goncalo Borges wrote:
> > Hi there,
> > I was hopping if someone could answer to the following question:
> > - Is it possible to run mpich2 jobs in a cluster where the users do not
> > share their homes across the different execution nodes?
> > If this is possible, I would like to know how can I implement the
> > procedure. What references should I look?
> > Thanks in advance
> > Cheers
> > Goncalo
