[MPICH] mpich without shared home directories
David Gunter dog at lanl.gov
Mon Apr 24 08:12:58 CDT 2006
I am curious about your setup.  How do you ensure the executable is
pushed out to all the execution nodes?  And do you run with
statically built binaries only or do you have a way of making sure
the necessary shared libs are available on the execution nodes?
-david
David Gunter
CCN-8: HPC Environments: Parallel Tools Team
Los Alamos National Laboratory
On Apr 24, 2006, at 5:50 AM, Goncalo Borges wrote:
> Hi there,
> I was hopping if someone could answer to the following question:
> - Is it possible to run mpich2 jobs in a cluster where the users do
> not
> share their homes across the different execution nodes?
> If this is possible, I would like to know how can I implement the
> procedure. What references should I look?
> Thanks in advance
> Cheers
> Goncalo
