[MPICH] MPI_GET_ADDRESS
Kenneth Rempe kenneth.rempe at studsvikscandpower.com
Fri Apr 21 13:51:49 CDT 2006
Bill,
Okay, what am I looking for in the configure output. Is there a why to
override what configure is setting?
Also, is this a problem because in C++ you can use an unsigned int for
addresses up to 4GB but in fortran it is a signed integer
which only can go up to 2GB?
Thanks
Ken
William Gropp wrote:
> At 08:02 AM 4/21/2006, Kenneth Rempe wrote:
>> On both the Linux and IBM the value of MPI_ADDRESS_KIND is set to a 4
>> byte integer.
> That's the problem.  If the sizeof a pointer is 8 bytes, then
> MPI_ADDRESS_KIND should be an 8 byte integer. What is the output of
> configure for MPICH2?  Note that MPICH2 must be configured with
> compatible compiler options for systems that support multiple datatype
> sizes (such as 32 and 64bit pointers).
> Bill
>> Linux   Red Hat Enterprise 3
>>           Lahey Fortran Compiler version 6.2c
>>           gcc version 3.2.3
>> IBM    Aix 5.2
>>           xlf compiler version 8.1
>>           xlc compiler version 6.0
>> *** NOTE: soa.com will no longer be used after February 1, 2006,
>> please change your address book ***
>> Kenneth R. Rempe                * email:
>> Studsvik Scandpower, Inc.       * 504 Shoup Avenue Suite #201     *
>> voice:  208-522-4630
>> Idaho Falls, ID USA 83402-3502  * fax:    208-522-1187
> William Gropp
> http://www.mcs.anl.gov/~gropp
*** NOTE: soa.com will no longer be used after February 1, 2006, please change your address book ***
Kenneth R. Rempe                * email: kenneth.rempe at studsvikscandpower.com
504 Shoup Avenue Suite #201     * voice:  208-522-4630
