[MPICH] MPI_GET_ADDRESS
William Gropp gropp at mcs.anl.gov
Fri Apr 21 13:20:21 CDT 2006
At 08:02 AM 4/21/2006, Kenneth Rempe wrote:
>On both the Linux and IBM the value of MPI_ADDRESS_KIND is set to a 4 byte
>integer.
That's the problem.  If the sizeof a pointer is 8 bytes, then
MPI_ADDRESS_KIND should be an 8 byte integer. What is the output of
configure for MPICH2?  Note that MPICH2 must be configured with compatible
compiler options for systems that support multiple datatype sizes (such as
32 and 64bit pointers).
Bill
>Linux   Red Hat Enterprise 3
>           Lahey Fortran Compiler version 6.2c
>           gcc version 3.2.3
>IBM    Aix 5.2
>           xlf compiler version 8.1
>           xlc compiler version 6.0
>*** NOTE: soa.com will no longer be used after February 1, 2006, please
>change your address book ***
>Kenneth R. Rempe                * email: kenneth.rempe at studsvikscandpower.com
>Studsvik Scandpower, Inc.       * 504 Shoup Avenue Suite #201     *
>voice:  208-522-4630
>Idaho Falls, ID USA 83402-3502  * fax:    208-522-1187
William Gropp
http://www.mcs.anl.gov/~gropp
