[MPICH] Passing class in C++ MPI
Yann Golanski
yann at kierun.org
Fri Apr 21 04:43:31 CDT 2006
Quoth Pankaj Gupta on Thu, Apr 20, 2006 at 14:06:23 -0400
> I am trying to parallelize a distributed simulation written in C++ having
> several classes. After reading several books, online manuals, and this mailing
> list, I still could not figure out a way to pass the class data from node 0 to
> all the processors or vice-versa. I came across other possible approaches such
> as MPI_Pack/Unpack or creating a string of the class data.
> My question is: Is it possible to pass a classes in C++ MPI (MPICH)? Any
> example, suggestions, or alternative approach will really help me.
Yes, I've had the same problem. Attached is some code I have done. It
should work for you as well.
You will need Boost to use it. But then again, you should use Boost
anyways.
yann at kierun.org -=*=- www.kierun.org
PGP: 009D 7287 C4A7 FD4F 1680 06E4 F751 7006 9DE2 6318
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20060421/b9a61d79/attachment.cc>
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20060421/b9a61d79/attachment.pgp>
