[MPICH] Aborting: connection to smpd rejected
Goncalo Borges goncalo at lip.pt
Thu Apr 20 06:04:25 CDT 2006
Hi there,
I'm trying to use a tight integration of MPICH with SGE. According to the
SGE staff how-to I should use the smpd mechanism for that. In my local cluster,
everything works correctly using:
mpiexec -ssh -nopm -n $NSLOTS -machinefile $TMPDIR/machines $HOME/$FILE_EXE
The problem is that my cluster is integrated in a global grid.
Users which try to run mpi jobs though the grid (in my cluster) get the
following error:
which I don't understand where it is coming from.
Could you explain what could be the reason of this error, keeping in mind
that the stuff works for local users but not for the grid environment?
Thanks in advance
Cheers
Goncalo
