[MPICH] mpdboot error : fail to ping
Rusty Lusk lusk at mcs.anl.gov
Sat Apr 8 09:57:56 CDT 2006
The Users' Guide suggests starting the mpd's by hand instead of using
mpdboot for the first experiments.  This makes it easier to detect
possible configuraton programs.  Also see the material there about
mpdcheck.
Rusty Lusk
From: "Misora Itsumo" <mitsuru.adachi at gmail.com>
Subject: [MPICH] mpdboot error : fail to ping
Date: Sat, 8 Apr 2006 05:58:39 +0700
> Hi
> i'm new to MPICH2 and i just installed mpich2 , but i can't make it run on a
> set of machines.
> i run mpich2 on 2 nodes  , hostnames are hewonty and vm1.
> Here are some info
> [hewonty at hewonty ~]$ cat mpd.hosts
> hewonty
> vm1
> [hewonty at hewonty ~]$ cat /etc/hosts
> 127.0.0.1       localhost.localdomain   localhost
> 192.168.2.2     hewonty.homelinux.org   hewonty.vmnet1.org      hewonty
> 192.168.2.3     vm1.hewonty.homelinux.org       vm1
> 192.168.2.2     svn_server
> [hewonty at hewonty ~]$ mpdboot -n 2 -f mpd.hosts
> mpdboot_hewonty (handle_mpd_output 359): failed to ping mpd on hewonty;
> recvd output={}
> i can ssh to hewonty or vm1.
> I tried to run mannually by mpd and here are what i got
> [hewonty at vm1 ~]$ mpd &
> [1] 2056
> [hewonty at vm1 ~]$ mpdtrace -l
> vm1_32772 (192.168.2.3)
> [hewonty at hewonty ~]$ mpd -h vm1 -p 32772
> hewonty_32846: mpd_uncaught_except_tb handling:
>   exceptions.TypeError: sequence item 0: expected string, int found
>     /usr/local/mpich2/bin/mpdlib.py  627  connect_lhs
>         response = md5new(''.join([self.secretword
> ,msg['randnum']])).digest()
>     /usr/local/mpich2/bin/mpdlib.py  564  enter_ring
>         numTries=ntries)
>     /usr/local/mpich2/bin/mpd  231  run
>         rhsHandler=self.handle_rhs_input)
>     /usr/local/mpich2/bin/mpd  1344  ?
>         mpd.run()
> Thanks in advance.
> Tiep
