[MPICH] Is ther a limitation with MPI_Comm_spawn_multiple
Rajeev Thakur
thakur at mcs.anl.gov
Wed Apr 5 19:02:39 CDT 2006
I haven't run your code, but I don't think you have allocated enough memory
in the commands array to do this:
> commands=(char**)malloc(sizeof(char)*num);
> commands[0]="./hello";
> commands[1]="./hello";
> commands[2]="./hello";
> commands[3]="./hello";
> commands[4]="./hello";
> commands[5]="./hello";
> commands[6]="./hello";
> commands[7]="./hello";
There is no limit in comm_spawn_multiple.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Rajesh Sudarsan
> Sent: Wednesday, April 05, 2006 6:15 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] Is ther a limitation with MPI_Comm_spawn_multiple
> Hi,
> I am using the MPI_Comm_spawn_multiple command in my program to
> dynamically spawn new processes. But the command does not
> seem to work
> when the number of spawned processes is greater than or equal to 5. I
> tested this using a simple master worker example. I have pasted the
> sample programs below. Could anyone tell me where I am going
> wrong or is
> this a limitation with the implementation?
> MASTER:
> #include<string.h>
> #include<stdlib.h>
> #include<stdio.h>
> #include <mpi.h>
> void
> main(int argc, char **argv)
> int tag = 0;
> int my_rank;
> int num_proc;
> char slave[20];
> int array_of_errcodes[10];
> int num,k;
> MPI_Status status;
> MPI_Comm inter_comm;
> char **commands;
> MPI_Info *info;
> int *maxprocs;
> char ***args=NULL;
> int i=1;
> char *host =(char*)"host";
> num = 8;
> maxprocs=(int *)malloc(sizeof(int)*num);
> maxprocs[0]=i;
> maxprocs[1]=i;
> maxprocs[2]=i;
> maxprocs[3]=i;
> maxprocs[4]=i;
> maxprocs[5]=i;
> maxprocs[6]=i;
> maxprocs[7]=i;
> MPI_Init(&argc, &argv);
> MPI_Comm_rank(MPI_COMM_WORLD, &my_rank);
> MPI_Comm_size(MPI_COMM_WORLD, &num_proc);
> info=(MPI_Info *)malloc(sizeof(MPI_Info)*num);
> MPI_Info_create (&info[0]);
> MPI_Info_create (&info[1]);
> MPI_Info_create (&info[2]);
> MPI_Info_create (&info[3]);
> MPI_Info_create (&info[4]);
> MPI_Info_create (&info[5]);
> MPI_Info_create (&info[6]);
> MPI_Info_create (&info[7]);
> MPI_Info_set (info[0],host, "n1026");
> MPI_Info_set (info[1],host, "n1027");
> MPI_Info_set (info[2],host, "n1028");
> MPI_Info_set (info[3],host, "n1029");
> MPI_Info_set (info[4],host, "n1050");
> MPI_Info_set (info[5],host, "n1051");
> MPI_Info_set (info[5],host, "n1052");
> MPI_Info_set (info[5],host, "n1053");
> printf("Master %d running on host\n",my_rank);
> printf("MASTER : spawning %d slaves ... \n",num);
> /* spawn slave and send it a message */
> MPI_Comm_spawn_multiple(num, commands, args, maxprocs, info,0,
> MPI_COMM_WORLD, &inter_comm, array_of_errcodes);
> MPI_Finalize();
> WORKER:
> #include <stdio.h>
> #include <mpi.h>
> main (int argc, char **argv)
> int node,k;
> int data1[1],data2[1]=10;
> MPI_Status *status;
> char host[20];
> MPI_Comm_rank(MPI_COMM_WORLD, &node);
> status = (MPI_Status*)malloc(sizeof(MPI_Status));
> if (node == 0) {
> printf("Rank 0 is present in C version of Hello World.\n");
> k=gethostname(host,20);
> printf("hostname = %s\n",host);
> data1[1]=11;
> printf("data received on proc %d\n",node);
> printf("%d\n",data2[1]);
> else {
> data1[1]=16;
> printf(" Rank %d of C version says: Hello world!\n", node);
> printf("-- %d\n",data2[1]);
> MPI_Finalize();
> Regards,
> Rajesh Sudarsan
