[MPICH] Is ther a limitation with MPI_Comm_spawn_multiple
    Rajesh Sudarsan
    rajesh.sudarsan at gmail.com
    Wed Apr  5 18:15:23 CDT 2006
I am using the MPI_Comm_spawn_multiple command in my program to
dynamically spawn new processes. But the command does not seem to work
when the number of spawned processes is greater than or equal to 5. I
tested this using a simple master worker example. I have pasted the
sample programs below. Could anyone tell me where I am going wrong or is
this a limitation with the implementation?
MASTER:
#include<string.h>
#include<stdlib.h>
#include<stdio.h>
#include <mpi.h>
void
main(int argc, char **argv)
        int             tag = 0;
        int             my_rank;
        int             num_proc;
        char         slave[20];
        int             array_of_errcodes[10];
        int             num,k;
        MPI_Status      status;
        MPI_Comm        inter_comm;
        char **commands;
        MPI_Info *info;
        int *maxprocs;
        char ***args=NULL;
        int i=1;
        char *host =(char*)"host";
       num = 8;
       commands=(char**)malloc(sizeof(char)*num);
       commands[0]="./hello";
       commands[1]="./hello";
       commands[2]="./hello";
       commands[3]="./hello";
       commands[4]="./hello";
       commands[5]="./hello";
       commands[6]="./hello";
       commands[7]="./hello";
        maxprocs=(int *)malloc(sizeof(int)*num);
        maxprocs[0]=i;
        maxprocs[1]=i;
        maxprocs[2]=i;
        maxprocs[3]=i;
        maxprocs[4]=i;
        maxprocs[5]=i;
        maxprocs[6]=i;
        maxprocs[7]=i;
        MPI_Init(&argc, &argv);
        MPI_Comm_rank(MPI_COMM_WORLD, &my_rank);
        MPI_Comm_size(MPI_COMM_WORLD, &num_proc);
        info=(MPI_Info *)malloc(sizeof(MPI_Info)*num);
        MPI_Info_create (&info[0]);
        MPI_Info_create (&info[1]);
        MPI_Info_create (&info[2]);
        MPI_Info_create (&info[3]);
        MPI_Info_create (&info[4]);
        MPI_Info_create (&info[5]);
        MPI_Info_create (&info[6]);
        MPI_Info_create (&info[7]);
        MPI_Info_set (info[0],host, "n1026");
        MPI_Info_set (info[1],host, "n1027");
        MPI_Info_set (info[2],host, "n1028");
        MPI_Info_set (info[3],host, "n1029");
        MPI_Info_set (info[4],host, "n1050");
        MPI_Info_set (info[5],host, "n1051");
        MPI_Info_set (info[5],host, "n1052");
        MPI_Info_set (info[5],host, "n1053");
    printf("Master %d running on host\n",my_rank);
    printf("MASTER : spawning  %d slaves ... \n",num);
        /* spawn slave and send it a message */
    MPI_Comm_spawn_multiple(num, commands, args, maxprocs, info,0,
MPI_COMM_WORLD, &inter_comm, array_of_errcodes);
     MPI_Finalize();
WORKER:
#include <stdio.h>
#include <mpi.h>
main (int argc, char **argv)
   int node,k;
   int data1[1],data2[1]=10;
   MPI_Status *status;
   char host[20];
   MPI_Comm_rank(MPI_COMM_WORLD, &node);
    status = (MPI_Status*)malloc(sizeof(MPI_Status));
   if (node == 0) {
     printf("Rank 0 is present in C version of Hello World.\n");
     k=gethostname(host,20);
     printf("hostname = %s\n",host);
     data1[1]=11;
      printf("data received on proc %d\n",node);
       printf("%d\n",data2[1]);
    else {
     data1[1]=16;
     printf("  Rank %d of C version says: Hello world!\n", node);
     printf("-- %d\n",data2[1]);
    MPI_Finalize();
Rajesh Sudarsan
