[MPICH] installing on sun. config.log attached
    Rob Ross
    rross at mcs.anl.gov
    Wed Sep 28 13:30:01 CDT 2005
Perhaps trying to build in a directory tree created by a different user,
where the current user cannot create files?
Rob
Rajeev Thakur wrote:
> Karl,
>      I don't know what this problem is. The configure script says "Can't
> open conftest.c". I don't know if that is a file permission problem.
> conftest.c is a file that configure itself creates. It's a mystery.
> Rajeev
>>-----Original Message-----
>>From: Karl Schleicher [mailto:karl at appliedgeo.com]
>>Sent: Wednesday, September 28, 2005 11:32 AM
>>To: Rusty Lusk
>>Cc: thakur at mcs.anl.gov; mpich-discuss at mcs.anl.gov
>>Subject: Re: [MPICH] installing on sun. config.log attached
>>Rusty or Rajeev,
>>I am working on installing Python.  I am still stuck with my original
>>problem that configure is failing much earlier.
>>I'm trying to install mpi on a cluster of Sun enterprise
>>systems. I want
>>to use several of our compute servers to solve one problem.
>>The steps I followed are:
>> ftp release to my computer
>>gunzip -c mpich2-1.0.2p1.tar.gz | tar -xovf -
>>cd mpich2-1.0.2p1
>>./configure |& tee configure.log
>>Configure fails  with the log:
>>Configuring MPICH2 version 1.0.2
>>sourcing /home/karl/mpi/mpich2-1.0.2p1/src/pm/mpd/setup_pm
>>checking for gcc... no
>>checking for cc... cc
>>cat: cannot open confdefs.h
>>checking for C compiler default output file name... Can't
>>open conftest.c
>>configure: error: C compiler cannot create executables
>>See `config.log' for more details.
>>I enterred "uname -a" to get:
>>SunOS m00 5.6 Generic_105181-29 sun4u sparc SUNW,Ultra-Enterprise
>>I have tried working on other systems to understand the
>>problem, but they are tangents.  I followed Rajeev
>>suggestions to set environment variables, rerun the tar
>>extraction, test the c compiler.
>>Thanks in advance,
>>Karl Schleicher
>>Applied Geophysical Services
>>Rusty Lusk wrote:
>>>To install the default mpd process manager, you will need to install
>>>Python (as the Installation Guide explains).  Python is free from
>>>python.org and is relatively easy to install.
>>>If you are going to run on a single machine, you can use a different
>>>process manager, which does not require Python.  Configure with
>>> configure ...  --with-pm=gforker  ...
>>>That will configure a different version of mpiexec, which
>>works fine for
>>>single hosts.
>>>Regards,
>>>Rusty
>>>From: Karl Schleicher <karl at appliedgeo.com>
>>>Date: Wed, 28 Sep 2005 07:35:12 -0500
>>>>Rajeev,
>>>>At your request, I removed all the directory created by tar
>>(including
>>>>the hidden subdirectory without execute permission).  I did
>>a fresh tar,
>>>>your recommended setenv's, and ./configure.  Results were
>>the same.  I
>>>>created a little c program (hello world) which compiled and ran
>>>>successfully.
>>>>I understand you routine build on solaris platform.  I to get much
>>>>further on my Sun desktop (SunOS 5.9 Ultra 30) before
>>failing because I
>>>>do not have Python installed.   My servers (SunOS 5.6
>>Ultra-Enterprise)
>>>>fail much sooner with the logs I sent you.  What experience
>>is there
>>>>with MPI on Enterprise systems?
>>>>Thanks,
>>>>Karl
>>>>>I don't know what's going on. The configure script is
>>unable to compile a
>>>>>simple test program. Can you create a small dummy C
>>program and see if it
>>>>>compiles and runs with cc. Otherwise, just do a fresh
>>untar of the tar file
>>>>>and try again. We routinely build on a Solaris platform,
>>so I don't know
>>>>>what's happening here.
>>>>>Rajeev
>>>>>>Sent: Tuesday, September 27, 2005 3:57 PM
>>>>>>To: Rajeev Thakur
>>>>>>Cc: mpich-discuss at mcs.anl.gov
>>>>>>Rajeev,
>>>>>>I've attached the config.log.
>>>>>>By the way I did not complete the config on my desktop Sun.
>>>>>>It failed
>>>>>>looking for python, which has not been installed.
>>>>>>Karl
>>>>>>>Could you send the config.log file?
>>>>>>>Rajeev
>>>>>>>>From: owner-mpich-discuss at mcs.anl.gov
>>>>>>>>[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Karl
>>>>>>Schleicher
>>>>>>>>Sent: Tuesday, September 27, 2005 2:00 PM
>>>>>>>>To: Rajeev Thakur
>>>>>>>>Subject: Re: [MPICH] Newbee having pblms installing on sun
>>>>>>>>Rajeev,
>>>>>>>>Results are very similar:
>>>>>>>>checking for gcc... cc
>>>>>>>>open conftest.c
>>>>>>>>I did complete the configuration on my desktop, but is
>>not try the
>>>>>>>>make.  On that computer "uname -a" produces:
>>>>>>>>SunOS c12 5.9 Generic_118558-06 sun4u sparc SUNW,Ultra-30
>>>>>>>>I wonder if the problem is the shared memory multi-processor
>>>>>>>>Enterprise.  I really need to lash up several of these
>>>>>>>>computers to work on my problem and want to use MPI to handle
>>>>>>>>the message passing.  I already have the code multi threaded
>>>>>>>>on one system.
>>>>>>>>Thanks,
>>>>>>>>Karl
>>>>>>>>>Try specifying the Sun compilers explicitly by setting the
>>>>>>>>environment
>>>>>>>>>variables CC, CXX, F77, F90 as
>>>>>>>>>setenv CC cc
>>>>>>>>>setenv CXX CC
>>>>>>>>>setenv F77 f77
>>>>>>>>>Setenv F90 f90
>>>>>>>>>Rajeev
>>>>>>>>Schleicher
>>>>>>>>>>Sent: Tuesday, September 27, 2005 9:28 AM
>>>>>>>>>>To: mpich-discuss at mcs.anl.gov
>>>>>>>>>>Subject: [MPICH] Newbee having pblms installing on sun
>>>>>>>>systems.  I
>>>>>>>>>>want to use several of our compute servers to solve one
>>>>>>>>>>problem.  I have
>>>>>>>>>>tried to do a little homework before asking for help,
>>but now I'm
>>>>>>>>>>stuck.  I would appreciate help getting past these problem.
>>>>>>>>>>cd mpich2-1.0.2p1
>>>>>>>>>>open conftest.c
>>>>>>>>>>Some of the things I have tried are:
>>>>>>>>>>- building on a Linux PC.  Successful.
>>>>>>>>>>- building mpich-1.2.7. It hangs looking "checking for c++"
>>>>>>>>>>- building mpich2 on another Sun system with different
>>>>>>>>>>os.  It hangs
>>>>>>>>>>after:
>>>>>>>>>>    "checking for g77... g77"
>>>>>>>>>>- The programmers and system administrators at my small
>>>>>>>>>>company are
>>>>>>>>>>unable to
>>>>>>>>>>      to help.
>>>>>>>>>>I have additional information that I will provide if this is
>>>>>>>>>>insufficient.
>>>>>>>>>>Thanks in advance for any help.
>>>>>>>>>>Karl Schleicher
