[MPICH] Machine with multiple IP addresses
David Ashton
ashton at mcs.anl.gov
Wed Sep 21 16:33:26 CDT 2005
Sophie Duchesne,
>From the limited information given, this appears to be an error on a Windows
machine using MPICH 1.2.5. We recommend all users to use the current
project, MPICH2, instead of MPICH. You can get it here:
http://www.mcs.anl.gov/mpi/mpich2
Try compiling with MPICH2 and see if this solves your problem.
If there still is an error there are several ways to select a specific
network interface. You can use the MPICH_NETMASK environment variable to
mask off a range of IP addresses you want to use or you can use the
MPICH_INTERFACE_HOSTNAME environment variable to specify a specific IP
address. You can also set the interface hostname through a machine file by
adding -ifhn x.x.x.x to each line after the host name.
Examples:
mpiexec -env MPICH_NETMASK 192.168.123.0/24 -n 3 myapp.exe
mpiexec -env MPICH_INTERFACE_HOSTNAME 192.168.123.101 -host foo -n 1 myapp :
-env MPICH_INTERFACE_HOSTNAME 192.168.123.102 -host bar -n 1 myapp : .
If you have to use MPICH 1.2.5, please read the manual that comes with it to
see how to select a specific IP address.
-David Ashton
_____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Sophie Duchesne
Sent: Wednesday, September 21, 2005 12:44 PM
Subject: [MPICH] Machine with multiple IP addresses
Hello all,
I am very new to MPICH and to parallel computing. One machine in our cluster
has 2 IP addresses. I am still trying to figure out how I can configure
MPICH in order for it to know which address to use. Currently, it does not
use the right address and I get this kind of messages:
Error 10065, process 5, host <hostname> Unable to connect to <IP
address> on port <port number>
Thank you for your help!
Sophie Duchesne
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20050921/0c208677/attachment.htm>
