[MPICH] MPICH2: Internal use of errno?
James Frye
frye at cs.unr.edu
Wed Sep 14 08:36:17 CDT 2005
I've encountered something unusual with some MPI code I'm writing. My
code is a communication layer that passes information between many
instances of a sequential program. The sequential program is in wide use,
so I can at most make very limited changes to it.
The sequential program tests the C errno variable at various places. When
I run it under MPICH2 (the mpd demon), it sees an errno=22 (Operation now
in progress), which seems to be coming from something MPICH is doing. I
can get rid of the effects by setting errno in my code in each iteration.
So my questions are 1) Is this known? and 2) Is it something I need to be
concerned with?
James
