[MPICH] mpich2 on G5
    Rachid Benshila
    Rachid.Benshila at lodyc.jussieu.fr
    Tue Sep 13 08:05:31 CDT 2005
Hi
I am using MPICH2 on a mac G5 for a fortran 90 code. I have 2 different
questions :
- installing MPICH2 with gcc and xlf90 works on panther (10.3) but
failed on tiger(10.4). I know xlf90 is not fully supported on tiger,
but It seems to be related to the gcc version,  I am not sure about
that. The mpich libraries are created but are not recognized as
librariries when I try to use it. Does someone have any experience
about that ?
- I am using  a single computer with 2 cpu and 2 different aims.
The first one  is to do preliminary tests for mpi before running on a
cluster. Here I do not mind of the performances and I am using the mpd
daemon as if I was working on two different computers, and it works
fine.
My second aim would be to perform "production" runs on my computer. Is
there a way to take advantage of running on a bi-processor using MPICH.
It is probably closer related to the code itself, but are there basics
recommandations to install MPICH ? Should I better use gforker instead
of mpd ? If someone use to run on a G5 or on a multi-processors
computer in general, any advice would be welcome.
Thanks a lot
Rachid
