[MPICH] Problem in Configuring mpich2-1.0.2
Rajeev Thakur
thakur at mcs.anl.gov
Fri Oct 7 11:42:51 CDT 2005
The rdma channel is unsupported, has not been tested in a while, and may not
work. The error you are seeing comes from the setup_channel.args file in the
channels/rdma directory. If you want you can edit that file and explicitly
set the rdma_name variable to iba. I don't know if you may encounter some
other error after that, but you can experiment.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of devesh sharma
> Sent: Friday, October 07, 2005 2:42 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] Problem in Configuring mpich2-1.0.2
> Hi I am compiling mpich2-1.0.2 with rdma-iba channel device but
> faceing problems in configure it self. The command I gave is following
> ./configure --prefix=/data3/mpich2 --with-device=ch3:rdma
> --with-rdma=iba --without-mpe --without-romio
> and error that comes is following
> sourcing /data2/mpich2-1.0.2/src/mpid/ch3/setup_device
> RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
> sourcing /data2/mpich2-1.0.2/src/mpid/ch3/channels/rdma/setup_channel
> RUNNING SETUP_CHANNEL FOR THE RDMA CHANNEL
> Error: --with-rdma not specified.
> What should I do?
