[MPICH] MPICH2 does not work over Windows XP network with ib card
Rajeev Thakur
thakur at mcs.anl.gov
Fri Nov 4 14:54:27 CST 2005
Yes, your test runs successfully to completion with our latest source.
Rajeev
PS: BTW, the preferred method of running is "mpiexec -n 1" instead of
"mpdrun -np 1"
> -----Original Message-----
> From: John Robinson [mailto:jr at vertica.com]
> Sent: Thursday, November 03, 2005 3:51 PM
> To: Rajeev Thakur
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] MPICH2 does not work over Windows XP
> Hi Rajeev,
> Thanks for the quick offer.
> I was able to induce the failure with the attached test program pair.
> Unzip/untar and read README. Should be pretty transparent.
> By the way, the system I am running on is:
> Linux 2.6.13-1.1532_FC4 #1
> Thanks for your help!
> /jr
> Rajeev Thakur wrote:
> > John,
> > In our upcoming release (in a couple of weeks) we do
> things quite
> > differently in this part of the code, and hopefully this
> problem will not be
> > there. In the meanwhile, if you can send us a small test
> program, we would
> > be happy to test it with the new code.
> > Rajeev
> >>From: owner-mpich-discuss at mcs.anl.gov
> >>[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of John Robinson
> >>Sent: Thursday, November 03, 2005 8:53 AM
> >>To: mpich-discuss at mcs.anl.gov
> >>Subject: [MPICH] MPICH2 does not work over Windows XP network
> >>with ib card
> >>Good morning everyone,
> >>New to this list, so please forgive if this is not quite the
> >>right forum
> >>(and redirect me) - thanks!.
> >>I have a setup where the cluster is running a long-lived
> >>server process
> >>that uses mpi_comm_accept to receive new client connections, and
> >>single-process client processes that call mpi_comm_connect to
> >>submit work.
> >>The problem happens after the first client process has
> >>completed and a
> >>new one tries to connect. I get the following fatal error from the
> >>server processes:
> >>MPI_Comm_accept(116):
> >>MPI_Comm_accept(port="port#35267$description#jr$",
> >>MPI_INFO_NULL, root=0, comm=0x84000001, newcomm=0xbf89b370) failed
> >>MPID_Comm_accept(29):
> >>MPIDI_CH3_Comm_accept(598):
> >>MPIDI_CH3I_Add_to_bizcard_cache(58): business card in cache:
> >>port#35268$description#jr$, business card passed:
> >>port#35269$description#jr$
> >>The accept code looks like:
> >> impl->acceptComm = MPI::COMM_WORLD.Dup( ); // Intracomm for new
> >>connections
> >> MPI::Intercomm clientComm; // result of Accept() call
> >> clientComm = impl->acceptComm.Accept(impl->serverPort,
> >>MPI_INFO_NULL, 0);
> >>The connect is:
> Connect() call
> >> clientComm = MPI::COMM_SELF.Connect( impl->serverPort,
> >>MPI_INFO_NULL, 0);
> >>One detail that may be relevant is that the client process is
> >>started on
> >>demand from a master process that forks the process that
> >>eventually does
> >>the connect(). So the original mpd job (the master process) is
> >>long-lived, but more than one separate forked processes are calling
> >>MPI_Init/Finalize. Does each of these need to be a
> separate MPI job?
> >>MPICH version: mpich2-1.0.2p1
> >>thanks,
> >>/jr
