[MPICH] mpich2-1.0.2 build errors
Joe Landman
landman at scalableinformatics.com
Wed Jun 22 08:12:02 CDT 2005
Hi folks:
Pulled 1.0.2 and built on an RHEL3 dual opteron machine with gcc
3.2.3 and Portland group compilers. Defined F77 and F90 to point to
compilers.
If I run
./configure --prefix=/path/to/install/directory
I get a working build
However, if I use
./configure --prefix=/path/to/install/directory --enable-timing=runtime
--enable-error-checking=runtime
we get an error:
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include
-I/root/mpich2-1.0.2/src/binding/f77
-I/root/mpich2-1.0.2/src/mpid/ch3/include
-I/root/mpich2-1.0.2/src/mpid/common/datatype
-I/root/mpich2-1.0.2/src/mpid/ch3/channels/sock/include
-I/root/mpich2-1.0.2/src/mpid/common/sock
-I/root/mpich2-1.0.2/src/mpid/common/sock/poll
-I/root/mpich2-1.0.2/src/mpid/common/sock/poll -c comm_set_attr.c
comm_set_attr.c: In function `PMPI_Comm_set_attr':
comm_set_attr.c:189: syntax error at end of input
make[3]: *** [comm_set_attr.o] Error 1
make[3]: Leaving directory `/root/mpich2-1.0.2/src/mpi/attr'
make[2]: *** [all-redirect] Error 2
make[2]: Leaving directory `/root/mpich2-1.0.2/src/mpi'
make[1]: *** [all-redirect] Error 2
make[1]: Leaving directory `/root/mpich2-1.0.2/src'
make: *** [all-redirect] Error 2
I looked at the comm_set_attr.c and did not see anything obvious. Is
this a known issue? Does this work with your compilers? Is 3.2.3 too
ancient for real work?
Thanks.
Joe
Joseph Landman, Ph.D
Founder and CEO
Scalable Informatics LLC,
email: landman at scalableinformatics.com
web : http://www.scalableinformatics.com
phone: +1 734 786 8423
fax : +1 734 786 8452
cell : +1 734 612 4615
