[MPICH] passwordless rsh/ssh
Syed Irfan irfan at itee.uq.edu.au
Tue Jun 21 21:27:59 CDT 2005
Hi Kevin,
Well you need to add the user who is going to rsh under $HOME/.rhosts
(refer 2)
if you want to use hostname instead of ip address add the appropriate
hostnames and ip address to /etc/hosts (refer 2)
1. for passwordless ssh look here:
http://www.massey.ac.nz/~jriden/passwordless-ssh.html
2. for passwordless rsh login look here:
http://users.tpg.com.au/devdsp/2.rsh_config.html
As always a lot of info provided in the mpich2 user manual. Thanks to
the authors of the manual very helpful :)
hth
Irfan
Kevin C. wrote:
> Dear all
> I manage to get rshd/rsh and ssh to work. I can rsh / ssh to myself
> localhost. I notice that I cannot log in as root via rsh and have to use
> a normal user account for rsh. Is this normal? Does it matter to MPICH
> whether it's root or not root passwordless login?
> When I ssh/rsh to another machine I have to use it's IP address. How do
> I get around this so that I can rsh/ssh using hostname?
> I manage to get ssh passwordless to localhost, but not to other hosts.
> If I was using ssh, how would I configure MPICH-1 to use ssh instead of
> it using rsh by default?
> Did anyone know how to make rsh passwordless?
