[MPICH] Tools to play(debug/monitor) with source - a developers perspective ?
    Rajeev Thakur
    thakur at mcs.anl.gov
    Tue Jun 14 14:02:03 CDT 2005
Ignore my comment about mpigdb. In MPICH2 1.0.2, mpigdb has been replaced by
mpiexec -gdb as described in the CHANGES file. The Users Guide has been
updated to reflect that, but src/pm/mpd/README still refers to mpigdb
(mistakenly).
Rajeev
> > On Tue, 14 Jun 2005, Rajeev Thakur wrote:
> > > You can also use the script mpigdb, which serves as a
> > parallel interface to
> > > gdb. Info on how to use it is in the Users guide and in
> > src/pm/mpd/README.
> > > Rajeev
> > > > -----Original Message-----
> > > > From: owner-mpich-discuss at mcs.anl.gov
> > > > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
> Anthony Chan
> > > > Sent: Monday, June 13, 2005 11:57 PM
> > > > To: Syed Irfan
> > > > Cc: mpich-discuss
> > > > Subject: Re: [MPICH] Tools to play(debug/monitor) with source
> > > > On Tue, 14 Jun 2005, Syed Irfan wrote:
> > > > > What tools are used to modify/debug/analyze/monitor mpi
> > > > source (API) ?
> > > > I am not sure what you mean by mpi source!  Here is what I know.
> > > > For debugging, you could use gdb/ddd (good for few processes)
> > > > mpiexec -n 2 ddd a.out
> > > > This is only possible with mpich2 and not mpich1.  For
> complicated
> > > > or large job, you may need totalview (I haven't tried
> > this with mpich2
> > > > yet, but the support is there).
> > > > For performance tunning:
> > > > --At user level, you could MPE's logging capability to profile
> > > >   your mpi code, i.e. you first generate a clog2 file by linking
> > > >   your code with mpe libraries and convert the file to
> slog2 file
> > > >   and view it in jumpshot.  I believe you can use TAU from
> > > > university of
> > > >   oregon.
> > > > --At developer level, you could configure MPICH2 with
> > rlog support.
> > > >   Running mpi code will generate a rlog file which contains
> > > > the details
> > > >   of mpich2's internal.  Again you can view rlog file
> > with jumpshot.
> > > > > An insight into the procedure or a blog from developers
> > > > perspective on
> > > > > his activity to improve/modify mpich source would be great :)
> > > > May not be what you are looking for, but our cvs
> > repository has been
> > > > posted on our website:
> > > > http://www-unix.mcs.anl.gov/~gropp/projects/parallel/MPICH/mpi
> > > > ch2/changes/index.html
> > > > and
> > > > http://www-unix.mcs.anl.gov/mpi/mpich2/cvsweb.cgi/
> > > > A.Chan
