[MPICH] Tools to play(debug/monitor) with source - a developers perspective ?
Rajeev Thakur
thakur at mcs.anl.gov
Tue Jun 14 08:57:01 CDT 2005
You can also use the script mpigdb, which serves as a parallel interface to
gdb. Info on how to use it is in the Users guide and in src/pm/mpd/README.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Anthony Chan
> Sent: Monday, June 13, 2005 11:57 PM
> To: Syed Irfan
> Cc: mpich-discuss
> Subject: Re: [MPICH] Tools to play(debug/monitor) with source
> On Tue, 14 Jun 2005, Syed Irfan wrote:
> > What tools are used to modify/debug/analyze/monitor mpi
> source (API) ?
> I am not sure what you mean by mpi source! Here is what I know.
> For debugging, you could use gdb/ddd (good for few processes)
> mpiexec -n 2 ddd a.out
> This is only possible with mpich2 and not mpich1. For complicated
> or large job, you may need totalview (I haven't tried this with mpich2
> yet, but the support is there).
> For performance tunning:
> --At user level, you could MPE's logging capability to profile
> your mpi code, i.e. you first generate a clog2 file by linking
> your code with mpe libraries and convert the file to slog2 file
> and view it in jumpshot. I believe you can use TAU from
> university of
> oregon.
> --At developer level, you could configure MPICH2 with rlog support.
> Running mpi code will generate a rlog file which contains
> the details
> of mpich2's internal. Again you can view rlog file with jumpshot.
> > An insight into the procedure or a blog from developers
> perspective on
> > his activity to improve/modify mpich source would be great :)
> May not be what you are looking for, but our cvs repository has been
> posted on our website:
> http://www-unix.mcs.anl.gov/~gropp/projects/parallel/MPICH/mpi
> ch2/changes/index.html
> and
> http://www-unix.mcs.anl.gov/mpi/mpich2/cvsweb.cgi/
> A.Chan
