[MPICH] Re: New version of MPICH2 (1.0.2)
    Rusty Lusk
    lusk at mcs.anl.gov
    Sat Jun 11 19:20:01 CDT 2005
> - The mpdrun/mpirun did not export the current LD_LIBRARY_PATH environment variable.
>    It seems however that it does export the other variables (PATH, PWD, ...) !
>    Spawning the processes with mpdboot and mpirun from the 1.0.1 version appears to
>    work with codes compiled with the 1.0.2 version!
You will want to use the MPI-2 standard 'mpiexec' instead of mpirun.
By default, it should export all environment variables.  Let us know if
it doesn't.
Rusty Lusk
