[MPICH] Re: New version of MPICH2 (1.0.2)
    Trach-Minh Tran
    trach-minh.tran at epfl.ch
    Sat Jun 11 16:29:51 CDT 2005
Hello,
I have just download, compiled the 1.0.2 version with Intel ifc on our
cluster (SuSE 9.0) and found 2 problems:
- The include/mpif.h uses comments with 'C' at the first column which the ifc
   compiler does not like, when included in *.f90 files. Notice that the 1.0.1 version
   uses the '!' type of comments instead.
- The mpdrun/mpirun did not export the current LD_LIBRARY_PATH environment variable.
   It seems however that it does export the other variables (PATH, PWD, ...) !
   Spawning the processes with mpdboot and mpirun from the 1.0.1 version appears to
   work with codes compiled with the 1.0.2 version!
Trach-Minh Tran.
