[MPICH] MPICH2+MPE on windows
David Ashton
ashton at mcs.anl.gov
Tue Jul 12 12:59:45 CDT 2005
Ok, I was wrong. The environment variable MPICH2_CHANNEL handles short
names and the variable MPI_WRAP_DLL_NAME handles one short name, mpe. If
MPI_WRAP_DLL_NAME is not "mpe" then it must be a name that the Windows
function LoadLibrary can resolve. It is always safe to pass in the full
name to the dll; for any other name you would have to look at the
documentation for LoadLibrary to see if it is valid.
-David Ashton
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of James S Perrin
Sent: Tuesday, July 12, 2005 7:06 AM
To: David Ashton; mpich-discuss at mcs.anl.gov
Subject: Re: [MPICH] MPICH2+MPE on windows
Hi David,
I found that "-env MPI_WRAP_DLL_NAME mpich2mpe" or rather better
"-genv
MPI_WRAP_DLL_NAME mpich2mpe" worked for me. Maybe windows also looks fo
"%s.dll"
I think you've got a little mixed up as MPICH2_CHANNEL seem to be
for setting
things like "ib" (inifiband) :) MPI_WRAP_DLL_NAME can be set "mpe" can be
set to
as the code also looks for dll's of the pattern "mpich2%s.dll"
Regards
James
David Ashton wrote:
> James,
> Thanks for pointing out the bug that -log is not global. If you specify
> then environment variable, MPI_WRAP_DLL_NAME, then you must specify the
> entire name - mpich2mpe.dll. If you use the MPICH2_CHANNEL environment
> variable then you can use the short name, mpe.
> -David Ashton
> From: owner-mpich-discuss at mcs.anl.gov
> Sent: Monday, July 11, 2005 8:46 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] MPICH2+MPE on windows
> Hi,
> This is a follow up to an earlier thread (Status of MPE2 on Windows)
> where it
> was stated that to run an mpi job with profiling you can use the
> (undocumented)
> -log to mpiexec (smpd only). This didn't work for my master/slave job
until
> I
> realised -log isn't a global option and has to be specified for each group
> of
> processes.
> However I noticed while digging around in the source code -log sets
> the wrapper
> dll to "mpe" whereas the suggested default is "mpich2mpe"
> (src/util/multichannel/mpi.c). I was wondering is there any difference, I
> didn't
> notice any when passing "-env MPI_WRAP_DLL_NAME mpich2mped" to mpiexec?
> Regards
> James
James S. Perrin, | email: james.perrin at manchester.ac.uk
Manchester Visualization Centre, | www.sve.man.ac.uk/General/Staff/perrin
Kilburn Building, The University, | tel: +44 161 275 6945
Manchester, England. M13 9PL. | fax: +44 161 275 6800/6040
"The test of intellect is the refusal to belabour the obvious" -Alfred
Bester
